| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
You can select any target that is a child or a parent of the zone (virtual platform, host, or server) and the zone will appear in the Navigation pane of the target.
The Virtualization Platform is the container on which zones are running. A global zone and all associated zones appear in a Zone Virtualization Platform page. A global zone is represented by a virtual server as well. Each non-global zone (virtual server) and kernel zone has its own Virtual Server page that displays details specific to that zone.
The following options are available on the All Targets page:
Click Virtualization Platform to see the list of virtual platforms. You can click any virtual platform in this list to open the virtual platform's home page.
Click Virtual Server to see the list of virtual servers.You can click any virtual server in this list to open the virtual server's home page.
Table 40-1 Location of Zone Information in the UI
| Object | Location |
Virtualization Platform |
A Virtual Platform target home page is accessible from the All Targets page, or from any of its parent or child targets through the Target Navigation pane. Click the All Targets selector at the top of the page. In the Refine Search section, select Virtualization Platform. The target can be a host, a server, or a zone target running on this Virtual Platform. A Target Navigation pane is located in the top left corner of a parent or child home page. Click the Target Navigation pane to expand it and see the Virtual Platform in the Navigation pane. |
Zone-specific (virtual server) page |
A zone virtual server target home page is accessible from the Solaris Zone Virtualization Platform page or the All Targets page. Click the All Targets selector at the top of the page. In the Refine Search section, select Virtual Server. If you are on the Solaris Zone Virtualization Platform page, click a zone to navigate to the virtual server page for that zone. |
