| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The Software Library File Transfer jobs submitted as part of different provisioning/patching procedure/job runs can be searched and viewed from the File Transfer Activity page.
File Transfer Activity Page
The File Transfer Activity page enables you to track file transfers related to Software Library.
To access this page, log in to Enterprise Manager Cloud Control and from the Enterprise menu, select Provisioning and Patching, then click Software Library. On the Software Library home page, from the Actions menu, select File Transfer Activity.
The table on this page shows all file transfer activities that have been performed recently. The Job Name column displays the job for which the file transfer activity was performed, and the Procedure Run Name column displays the Deployment Procedure run name if it is run within a Deployment Procedure. Both these columns together can be used to identify the file transfer activity.
