| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
This section describes the prerequisite for an Oracle ZFS Storage Appliance on engineered systems. A non-root user should have required privileges to view the analytic datasets. If the specific privileges are not assigned, then the analytic metrics displays an error.
If you need data to be collected for the following metrics, the corresponding datasets must be enabled in Oracle ZFS Storage Appliance.
| Metric name | DatasetName |
| Replication statistics by Direction | repl.bytes[direction],repl.ops[direction] |
| Replication Ops by Latency | repl.ops[latency] |
| IOopsByLatency | io.ops[latency] |
| L2ARC statistics | arc.l2_accesses[hit/miss],arc.l2_bytes,arc.l2_size |
| NAS IO statistics | nfs2.bytes, nfs3.bytes,nfs4.bytes |
You can add an extra privilege to a non-root user to access datasets.
To add a privilege in the appliance's user interface, perform the following steps:
You can also add an exception to a non-root user using Command Line Interface for reading analytics dataset. For example:
zfssa:> configuration users
zfssa:configuration users> select oemuser
zfssa:configuration users oemuser> exceptions
zfssa:configuration users oemuser exceptions> create
zfssa:configuration users oemuser auth (uncommitted)> set scope=stat
scope = stat
zfssa:configuration users oemuser auth (uncommitted)> set allow_read=true
allow_read = true (uncommitted)
zfssa:configuration users oemuser auth (uncommitted)> commit
