| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
You can configure the host, its credentials, and archive location information for a WebLogic domain and for all targets under the domain. You can either configure everything collectively under the target at the same time, or you can configure the targets individually.
To configure all of the targets at the same time, follow these steps:
To configure the targets separately, follow the procedure above, except select a particular target rather than the WebLogic domain.
