| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
You can select any target that is a child or a parent of the logical domain (virtual platform, host, or server) and the logical domain will appear in the Navigation pane of the target.
The Virtualization Platform is the container on which logical domain virtual servers or zones are running.
The following options are available on the All Targets page:
Click Systems Infrastructure Virtualization Platform to see the list of virtual platforms. You can click any virtual platform in this list to open the virtual platform's home page.
Click Systems Infrastructure Virtual Server to see the list of virtual servers.You can click any virtual server in this list to open the virtual server's home page.
Table 41-1 Location of Oracle VM Server for SPARC Information in the UI
| Object | Location |
Virtualization Platform |
A Virtual Platform target home page is accessible from the All Targets page, or from any of its parent or child targets through the Target Navigation pane. Click the All Targets selector at the top of the page. In the Refine Search section, select Systems Infrastructure Virtualization Platform. Alternatively, select any target that is a parent or a child of the Virtual Platform in the All Targets selector. The target can be a host, a server, or a logical domain target running on this Virtual Platform. A Target Navigation pane is located in the top left corner of a parent or child home page. Click the Target Navigation pane to expand it and see the Virtual Platform in the Navigation pane. |
Virtual Server |
A logical domain virtual server target home page is accessible from the zone Virtualization Platform page or the Virtual Server page. Click the All Targets selector at the top of the page. In the Refine Search section, select Systems Infrastructure Virtual Server. If you are on the Virtualization Platform page, click a zone to navigate to the virtual server page for that zone. |
