| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
You can perform the following actions, depending on the requirements.
Discover switches, and network-connected targets. When you discover a network-connected target such as a fabric, its datalinks and networks also become discovered assets.
View the configuration of fabrics, datalinks, and networks.
Diagnose problems using incidents and performance metrics.
Modify how the targets are monitored and how performance is measured.
