Go to primary content
Oracle® Enterprise Manager Cloud Control Administrator's Guide
13c Release 2
E74458-09
Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
Task Title
The Oracle SuperCluster can be removed in Enterprise Manager without SuperCluster members. So If the rack Oracle SuperCluster is deleted, the targets which are part of the Oracle SuperCluster System are not deleted from the Enterprise Manager and can be still accessed in the All Targets view. Or Oracle SuperCluster can be removed including targets which are part of the Oracle SuperCluster System. In this case targets placed in racks which are part of the Oracle SuperCluster System will be removed too.
Perform the following steps to delete Oracle Supercluster:
  1. In the rack landing page, select the Target menu drop-down list.
  2. Select Target Setup, then click Remove Target.
  3. If you want remove targets which are part of the Oracle SuperCluster System, select “Remove all targets associated to target Oracle Supercluster”. A list of targets which are part of the Oracle SuperCluster system will be shown.
  4. Some targets cannot be removed. Such targets have a red cross in the column Removal Details including a reason of why target cannot be removed. Unremovable targets will not be removed when Oracle SuperCluster target is removed.
  5. Some targets provide a custom removal flow (like SNMP monitoring unsubscription). Such targets have a yellow exclamation mark in the column Removal Details. If you want to remove target with a custom removal flow, go to the target’s landing page and remove the target from there. If you don't remove targets with custom removal flow, they will be removed along with Oracle SuperCluster without custom removal options available in their removal flows.
  6. Click Yes to confirm. Oracle SuperCluster is deleted.
