| Oracle® Enterprise Manager Cloud Control Administrator's Guide 13c Release 2 E74458-09 |
![]() Previous |
![]() Next |
The Logical View tab in the main window displays detailed information about the hardware components and capabilities. You can select one of the tabs to view detailed information about it.
The CPU tab shows CPU and CPU usage information.
The top section shows summary information. A pie chart displays the number of installed and available CPUs.
The following fields are displayed:
Architecture
Clock Speed
Model
CPU Power Consumption (Watts)
Overall Status
The bottom section displays a table showing the available processors, including name, active cores, serial numbers, part number, overall cache in KB, component location, and operational status.
The Memory tab shows overall memory and DIMM-specific information.
The top section shows summary information. A pie chart displays the number of installed and available DIMMs.
Memory (GB)
Memory Power Consumption (Watts)
Overall Status
The bottom section displays a table showing the memory modules, including the memory component name, size in GB, manufacturer, part number, serial number, location, and operational status.
The Power tab shows power and power supply information.
The top section shows summary information. A pie chart displays the number of installed and available power supplies. The overall status of the power supply is displayed.
The bottom section displays a table showing the available power supplies, including name, manufacturer, part number, serial number, output power in watts, location, and operational status.
The Fan tab shows cooling and fan information.
The top section shows summary information. A pie chart displays the number of total and available power supply unit fans. The overall status of the cooling is displayed.
The bottom section displays a table showing the available fans, including name, RPM as a percentage of maximum, location, and operational status.
The Storage tab shows information about the available storage.
The top section shows summary information. The following fields are displayed:
Total Installed Storage (GB)
Installed Disk
The bottom section displays a table showing the available storage disks, including the name, size in gigabytes, manufacturer, serial number, part number, and operational status. This information is displayed only if the ILOM is discovered.
The Disk Controller tab displays a table of the available disk controllers, including name, model, manufacturer, serial number, and operational status.
The Disk Expander tab displays a table of the available disk expanders, including name, manufacturer, version, model, firmware version, and chassis ID.
The Network Ports tab displays information about network interface controllers and network adapters.
The top section shows NIC and status information. The following fields are displayed:
Installed Ethernet NICs
Overall Status
The bottom section shows a table of network ports, including name, MAC address, description, and operational status.
The PCI Devices tab displays a table of the PCI devices, including name, description, device class, PCI device ID, PCI vendor ID, PCI end point, PCI sub device ID, and PCI sub device vendor ID.
This information is displayed only if an Agent is deployed on an operating system on the server.
The PDOMs tab displays a table of the physical domains for M-series hardware, including name, configuration status, assigned DCUs, and operational status.
