Understand the Oracle Determinations Engine
The Oracle Determinations Engine provides high-performance rule execution that can be easily embedded into Java and .NET applications, giving software developers full and direct access to its underlying functions. Organizations can use the Determinations Engine to embed powerful rules-based inferencing directly into their enterprise applications, providing an important alternative to other Oracle deployment offerings.
High performance inferencing
The Oracle Determinations Engine exposes the full power of Oracle’s patented Linear Inferencing algorithm, supporting the development of ultra-fast, rules based batch processing applications.
By directly accessing the Determinations Engine, you can maximize the speed at which large data sets can be processed; for example, recalculating insurance premiums across a customer base to deal with a change in policy.
Benchmarks confirm that the Determinations Engine can process millions of records in a matter of hours using cheap, commodity hardware. Excellent scalability enables higher processing speeds with more powerful hardware.
Web Determinations application development
The Oracle Policy Automation Determinations Engine provides full support for the development of custom Web Determinations rules based applications, enabling organizations to create specialized user interfaces or user interfaces that seamlessly integrate with existing enterprise applications.
Oracle’s own out-of-the-box user interface, Oracle Policy Automation Web Determinations, is implemented using the Engine.
The Oracle Policy Automation Determinations Engine is the foundation of Oracle’s deployment technology, providing all basic services for executing rules based applications across the following four main areas:
Inferencing
Metadata
Natural language
Screen handling
The Engine exposes its functionality through a well-defined application programming interface which is available in both Java and .NET versions, allowing it to be used with J2EE server platforms such as WebLogic, WebSphere and Oracle AS, in addition to Microsoft's standard platform; that is, COM+, ASP.NET, IIS.
The Engine is multithreaded, runs in-process and is able to work with as many rule sets as are required.  It can simultaneously process multiple concurrent requests across multiple rule sets.  It also scales well from single computer installations such as a standalone laptop all the way up to large production environments comprising clustered multiprocessing server farms.
Programming examples
Follow the links below to find reference examples for software engineers using the Determinations Engine API. It is written specifically from a Java perspective and includes code samples given in both Java and C#. Software engineers using the Determinations Engine API for .NET should also read the guide to using the Determinations Engine API for .NET.
The following examples are provided:
Retrieve a Decision Report
Rulebase configuration file
