Loads/Reloads a specified rulebase. The exact behavior of this operation is dependent on the underlying Rulebase Resolver plugin used by the Determinations Server, or more specifically the behavior of that plugin's loadRulebase method. For the default rulebase services provided by the Interview Engine, the behavior is:
Located at examples\rulebases\compiled\SimpleBenefits.zip in the Oracle Policy Automation Runtime package.
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://oracle.com/determinations/server/10.4/server/types">
<soapenv:Header/>
<soapenv:Body>
<typ:load-rulebase-request>
<typ:rulebase>SimpleBenefits</typ:rulebase>
</typ:load-rulebase-request>
</soapenv:Body>
</soapenv:Envelope>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:i18n="http://www.w3.org/2005/09/ws-i18n" xmlns:typ="http://oracle.com/determinations/server/10.4/server/types">
<SOAP-ENV:Header>
<i18n:international>
<i18n:locale>en_US</i18n:locale>
<i18n:tz>GMT+08:00</i18n:tz>
</i18n:international>
</SOAP-ENV:Header>
<SOAP-ENV:Body>
<typ:load-rulebase-response>
<typ:rulebase-loaded>SimpleBenefits</typ:rulebase-loaded>
</typ:load-rulebase-response>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
If there is an error reloading the rulebase, a SOAP Error with message indicating the type of error will be returned.
