12 Introduction to Oracle Help for Java Developer's Kit
This chapter introduces Oracle Help for Java Developer's Kit (OHJDK), the contents of OHJDK, and how to install OHJDK.
This chapter includes the following sections:
12.1 About Oracle Help for Java Developer's Kit
Oracle Help for Java Developer's Kit is a set of Java components and an API for developing and displaying HTML-based help content in a Java environment. It includes the Oracle Help for Java (OHJ) engine and additional tools necessary for implementing context-sensitive help in Java applets and applications.
The Oracle Help for Java engine is a full-featured Java-based help system for Java applications and applets. It provides pure Java components for navigating and displaying context-sensitive help. Oracle Help for Java is available for free, and may be redistributed as the help system for your application (see the license distributed with the release).
Oracle Help for Java supports help content in several file formats, including extensions of the JavaHelp and Microsoft's HTML Help standards. If you are authoring help content without using a help authoring tool, it is recommended that you read about Oracle Help file formats. If you are using a third party help authoring system that supports OHJ, refer to the documentation provided.
12.2 Oracle Help for Java Runtime in JDeveloper
The Oracle Help for Java runtime library, ohj.jar, is distributed as part of JDeveloper. Developers integrating Oracle Help for Java with their applications can modify their project settings to add the Oracle Help for Java library as a dependency. The full Oracle Help for Java release including sample code, helpset authoring wizard, indexer, and demos is available at no cost from the Oracle Help page on Oracle Technology Network at:
http://www.oracle.com/technetwork/topics/index-083946.html
12.3 Getting Started with the OHJDK
The Oracle Help for Java Developer's Kit (OHJDK) is a set of Java components and an API for developing and displaying HTML-based help content in a Java environment. It includes the Oracle Help for Java (OHJ) engine and additional tools necessary for implementing context-sensitive help in Java applets and applications.
This section describes the contents of the OHJDK and tells how to set up for developing OHJ help systems. It contains the following subsections:
12.3.1 Installing OHJDK
The following steps describe OHJDK installation process:
  • Download the latest Oracle Help for Java Developer's Kit from OTN. For Windows, you may download the Windows executable file or Executable JAR file. For Solaris or UNIX, download the binary file.
  • In Windows, double click the Windows executable file or executable JAR file to start the installation wizard. By default, the OHJDK is installed at C:\Program Files\ohelp location. For Solaris and UNIX, run the binary file to start the installation wizard.
  • Open the install folder and verify the files as described in Section 12.3.2, "Contents of an OHJDK Release".
12.3.2 Contents of an OHJDK Release
The OHJDK includes the compiled libraries for the OHJ engine, and libraries for the authoring tools and demonstrations. These libraries are distributed in JAR (Java ARchive) format. The OHJDK also includes documentation, including this document.
The files are discussed in the following sections:
12.3.2.1 OHJ Engine
These files contain binary files for the OHJ engine implementation and its dependencies. You must redistribute these files with your product application.
Table 12-1 OHJ Binaries
File Contents
ohj.jar
The help engine optimized binaries.
oracle_ice.jar
Oracle's customized version of the ICEbrowser from ICEsoft Technologies, Inc. The OHJ engine uses the ICEbrowser for displaying HTML topics.
12.3.2.2 Authoring Tools
The following JAR files contain the implementation for the Helpset Authoring Wizard and the Text Search Indexer. These files are not intended for distribution with your product application.
Table 12-2 OHJ Authoring Tools
File Contents
help-wizard.jar
Helpset Authoring Wizard implementation. Authors can run the Helpset Authoring Wizard using batch files created in the bin directory of their OHJDK installation.
help-indexer.jar
OHJ Text Search Indexer implementation. Authors can use the Full-Text Search Indexer to process and create Oracle Help search index (.idx) files.
12.3.2.3 Demonstration Files
The following JAR file contains the demonstration programs distributed with the OHJDK. This file is not intended for distribution with your product application.
Table 12-3 OHJ Demonstration JAR File
File Contents
help-demo.jar
Demonstration binaries and source code, plus sample documentation in HTML and the Oracle Help control file formats.
To run the demonstration programs, execute the batch files located in the bin subdirectory of your OHJDK installation. The OHJ installer for Windows adds shortcuts to the Windows Start Menu. The sample content used by the demo programs is located in the demodoc subdirectory.
When integrating OHJ with your application, it may be helpful for you to examine the source code for the demonstration programs (located in the helpdemo-version_num.jar file. The following demos are particularly helpful:
Table 12-4 OHJ Demonstration Files
File Contents
ChoiceDemo.java
(OHJ Features Demo)
Sample Java code that illustrates the following features:
  • Constructing the Help object
  • Adding helpsets (data)
  • Displaying the OHJ navigator window
  • Displaying multiple helpsets
CSHDemo.java
(Context-Sensitive Help Demo)
  • Launching the help system from a menu
  • Associating help topics with particular application controls
  • Enabling the F1 key to launch help
  • Implementing right-click pop-up menu help
12.3.2.4 Documentation
The following documentation is included with the OHJDK:
Table 12-5 OHJ Documentation
Document Content Location in OHJDK release
OHJ API Reference Documentation
Reference documentation for the OHJ Application Programming Interface (API), provided as JavaDoc.
The doc/javadoc subdirectory of the OHJDK installation. To view the API documentation, open the index.html file in an HTML browser.
Oracle Help Guide
This document
The doc subdirectory of the OHJDK installation.
12.3.3 Setting the Java CLASSPATH for OHJDK Development
To develop with the OHJDK, you must add the OHJ engine libraries and toolkit dependencies to your environment class path.
For example:
  • On Windows 2000 or XP, set the CLASSPATH variable in the Environment Variables dialog, accessed from the Advanced tab of the System Properties control panel.
  • On Windows NT, set the CLASSPATH variable in the Environment tab of the System Properties control panel.
  • On Windows 95/98, use the SET command in your autoexec.bat file.
  • On UNIX, use the setenv command to set an environment variable for your shell.
Consult the documentation for your Java Virtual Machine (JVM) and operating system to determine how to set the CLASSPATH variable.
