This document describes how to use Oracle Stream Analytics. The User Guide describes the various tasks that a user can perform using Oracle Stream Analytics.
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers that have purchased support have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
For more information, see the following documents:
Known Issues for Oracle SOA Products and Oracle AIA Foundation Pack at: http://www.oracle.com//technetwork/middleware/soasuite/documentation/soaknown-2644661.html.
Developing Applications for Event Processing with Oracle Stream Analytics
Getting Started with Event Processing for Oracle Stream Analytics
Schema Reference for Oracle Stream Analytics
Using Visualizer for Oracle Stream Analytics
Customizing Oracle Stream Analytics
Developing Applications with Oracle CQL Data Cartridges
Oracle CQL Language Reference
Java API Reference for Oracle Stream Analytics
Administering Oracle Stream Analytics
Getting Started with Oracle Stream Analytics.
Oracle Database SQL Language Reference at: http://docs.oracle.com/cd/E16655_01/server.121/e17209/toc.htm
SQL99 Specifications (ISO/IEC 9075-1:1999, ISO/IEC 9075-2:1999, ISO/IEC 9075-3:1999, and ISO/IEC 9075-4:1999)
Oracle Stream Analytics Forum: http://forums.oracle.com/forums/forum.jspa?forumID=820
The following text conventions are used in this document:
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, or terms defined in text or the glossary. |
italic |
Italic type indicates book titles, emphasis, or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
