Oracle RightNow Cx has two different types of objects associated with it: standard business objects and custom objects upon which you can perform CRUD operations. In this use case, you perform a Get
operation on a custom object and generate the appropriate WSDL and JCA file.
To perform the Get operation on a custom object:
Contact
, followed by CustomObj
(for example, Contact_CustomObj
).Contact_CustomObj
as an example under Available, and using the arrow, move the selected object to Selected.Get
to perform a Get
operation on the selected object.
