If the Localize Files dialog is displayed during adapter configuration, click Cancel. You cannot localize the WSDL file.composite.xml
file, right-click and select Oracle RightNow Adapter.Figure 5-10 Storing WSDL at an MDS Location
oramds:/apps/SOA/WSDLs/Integration/rightnowAPI.wsdl
An alternative is to directly provide the https URL:
https://integration-test.rightnowdemo.com/cgi-bin/integration_test.cfg/services/soap?wsdl
Oracle JDeveloper displays the Operations page.
Figure 5-11 Oracle RightNow Adapter Operations Screen
On the same screen, move Account
from the list of Available objects to the list of the Selected objects.
Create
operation returns a valid ID for a batch operation instance you are creating.Figure 5-12 The Services, Components and External References Screen Showing the Adapter in External References Swimlane
