Manage Warehouse Languages
Use this tab to specify the languages for which data will be loaded into Oracle Business Analytics Warehouse during the ETL process. When you install Oracle BI Applications, the American English Language is enabled by default. You must enable the languages that you want to deploy.
You can also specify a Base Language. The Base Language is used if the ETL process cannot locate data in any one of the enabled languages. For example, if French is an enabled language and American English is the Base Language, there will be two rows, one for each language. If French values are not available, then American English values will be substituted.
Element | Description |
Manage Business Analytics Warehouse Languages |
Use this list to view the available languages, and enable the languages that you want to support. Use the Installed column to change the default value of Disabled to Installed, which enables the selected language. The other table columns display read-only data. |
Set Base Language |
Use this option to specify the Base Language, which is marked with a blue dot. You can only specify one Base Language. American English is the default Base Language. To select a different Base Language, select a record in the table, then click the Set Base Language icon. If the current Base Language record is selected, then this icon is grayed out. |
