(Release 9.2 Update) Voiding Joint Venture Distribution Documents Using a Batch Process (R09J414)
The Void JVM Distribution Detail program (R09J414) enables you to void multiple distribution documents at the same time. You can set up the processing options for the program to void or delete large volumes of distribution documents that match the selection criteria.
After the R09J414 program completes processing, if any of the selected distribution documents are not voided, the corresponding errors are reported to the work center.
