Defining and Using Default Job Queues (Release 9.2.6)
To define a default job queue, access the Work With Default Output Locations program (P98617).
- Select Job Queues from the Form exit to access Work With Default Report Job Queues.
- Click Add to create a new record or select an existing record for which you want to define the default job queue.
- In the Default Report Job Queue Revisions form, complete the following fields:
Field | Description |
User/Role | Define the user for the default report job queue. |
Report Name |
Click the visual assist to select the report for which you want to define the default report job queue. Enter *ALL to apply the report job queue to all the reports. The *ALL entry does not apply to child reports if they do not have a specific override setting. They inherit the settings of their respective parent reports. |
Version Name | Click the visual assist to select the version of the report for which you want to define the default report queue. If the value in the Report Name field is *ALL, the system populates the Version Name field with the default value of *ALL and makes the field unavailable for subsequent modification. |
Environment | JD Edwards EnterpriseOne provides a default value for this field based on the environment that you are currently logged onto. Enter *ALL for all the environments. You can change this information. |
Default Report Job Queue | Click the visual assist to open Job Queue Search & Select. Select the default queue you want the report to run in. |
Host Name | Enter the name of the host server where reports will be processed. The visual assist displays the appropriate host names based on the default report job queue you select. To use this default report job queue for all the hosts in your environment, enter *ALL. |
Object Status | Define the default report job queue as active by changing its status to active. |
Note: If you call a child job with a synchronous report interconnect, it will run in its
parent job queue because a synchronous job runs inside the parent job’s process ID.
However, if a parent job calls a child job with an asynchronous report interconnect, the
child job can be mapped to any queue. After you have configured the default job queue,
it is applicable for all submission paths.
