Understanding the Work With Locations and Machines Web Program (Release 9.2.5)
Important: It is recommended to restrict this application to EnterpriseOne administrators.
The Work With Locations and Machines Web (P9654W) program enables you to define or revise machines and locations in your enterprise. In addition, you can use the Work With Locations and Machines Web (P9654W) program to define deployment locations. When you add a new deployment server definition, the system creates a record in the F9650 table for each deployment location. Each server at each deployment location must be defined.
In addition to defining workstations, you can also use the JD Edwards EnterpriseOne Deployment Locations application to enter or revise definitions for these machines:
  • Deployment Server
  • Enterprise Server
  • Virtual Host
  • Data Server
  • Java Application Server
  • Windows Terminal Server
  • Business Services Server
You can enter or revise definitions for these machines in multiple locations, including remote locations.
