Setting up Insights Dashboards for General Ledger
PeopleSoft General Ledger delivers Insights dashboards to analyze general ledger data using different visualizations.
To set up Insights dashboards for General Ledger:
  1. Use the Insights Reporting Tree Configuration Page to determine the reporting account and department tree to be used when indexing Insights dashboards for General Ledger.
  2. Use the Insights Preferences Page to configure user defaults that are used when accessing dashboards for General Ledger and Commitment Control.
  3. Use the Deploy Search Definition page to deploy the search definition (PeopleTools, Search Framework, Administration, Deploy Search Objects).
    The PeopleSoft General Ledger search definitions are:
    • EP_GL_LEDGER_KIB
    • EP_GL_JOURNAL_KIB
    • EP_GL_ACT_BUDG_LEDG_KIB
    See also Application Fundamentals: Search Definitions and Privileges for a list of General Ledger search definitions for PeopleSoft Insights dashboards.
  4. Use the Schedule Search Index page to run the Build Index process (PeopleTools, Search Framework, Administration, Schedule Search Index).
    The first time you run this process for a search index, you should always select Full Index as the Indexing type. You can run incremental indexes after that.
  5. Use the Deploy Insights dashboards page to deploy the dashboard and the tile (PeopleTools, Search Framework, Administration, Deploy Insights Dashboards).
    When you deploy a dashboard, you are copying the dashboard from the PeopleSoft database to your instance of PeopleSoft Insights. The deployed dashboard is then available on the Saved Objects page in the Management section on the Insights home page. Use the Deploy Insights Dashboards page to deploy or update a dashboard. For more information on Deploying a Dashboard, see PeopleTools:Search Technology, Working with Insights Dashboards for PeopleSoft Application Data, Deploying a Dashboard.
  6. Use the Application Fundamentals: Personalize Homepage Page to add the tile to a homepage.
  7. Use the User Roles page to add the privileges to users (PeopleTools, Security, User Profiles, User Profiles).
    The PeopleSoft General Ledger privileges are:
    • Insights GL Edit Privilege
    • Insights GL View Privilege
    See also Application Fundamentals: Search Definitions and Privileges for a list of all product privileges for PeopleSoft Insights dashboards.
  8. Add tiles to a homepage. See Adding General Ledger Tiles for Insights Dashboards.
Pages Used to Set up Dashboards for General Ledger
GL_KIB_DFLT_TREE
Determine the reporting account and department trees to be used when indexing Insights dashboards for General Ledger.
GL_K_USER_DEFAILTS
Configure user defaults that are used when accessing dashboards for General Ledger and Commitment Control.
Application Fundamentals: User Preferences - Overall Preferences Page
OPR_DEF_TABLE_FS1
Define overall default user preferences for specific PeopleSoft system users.
The Business Unit field is used as the default business unit for all General Ledger and Commitment Control Insights.
Application Fundamentals: User Preferences - General Ledger Page
OPR_DEF_TABLE_GL1
Set up user defaults for General Ledger.
The Ledger field is used as the default ledger for Financial Performance Insights dashboard.
General Ledger Definition - Definition Page
BUS_UNIT_TBL_GL1
Define a General Ledger business unit.
The Base Currency field is used as the default currency code, based on the user’s Business Unit preference, for all General Ledger and Commitment Control Insights.
Use the Insights Reporting Tree Configuration page (GL_KIB_DFLT_TREE) to determine the reporting account and department trees to be used when indexing Insights dashboards for General Ledger.
Navigation:
Set Up Financials/Supply Chain , and then Operating Reporting , and then GL Insights Tree Configuration
This example illustrates the fields and controls on the Insights Reporting Tree Configuration page.
Field or Control Description
ChartField
Select a ChartField to assign to the respective reporting tree. Insights dashboards for General Ledger are designed to support only account and department ChartFields
Tree SetID
Select the SetID for the tree. Multiple reporting trees can be configured for a ChartField and Tree SetID combination
Tree Name
Select a flattened tree name and effective dated row that is used to index the reporting tree for General Ledger Insights dashboards.
Note: Before selecting the tree name, you must run the Tree Flattener Process for the reporting tree using the Application Fundamentals: Tree Flattener Request Page.
Use the Insights Preferences page (GL_K_USER_DEFAILTS) to configure user defaults that are used when accessing dashboards for General Ledger and Commitment Control.
Navigation:
Set Up Financials/Supply Chain , and then Common Definitions, and then User Preferences, and then Define User Preferences, and then General Ledger, and then General Ledger. Select the Insights Preferences link.
This example illustrates the fields and controls on the Insights Preferences page.
Insights Preferences (General Ledger)
Enter a default for the available fields.
When adding Insights dashboard tiles to a General Ledger homepage, access the General Ledger folder. PeopleSoft General Ledger has these tiles associated with Insights dashboards:
For additional information about how to add a tile to a PeopleSoft Fluid Home page, see Application Fundamentals: Adding Homepages and Tiles and PeopleTools: Application User’s Guide, “Working With PeopleSoft Fluid User Interface”, Working with Fluid Homepages and Dashboards, Managing Tiles on Fluid Homepages and Dashboards.
This example illustrates the GL Operational Insights Tile.
This example illustrates the Financial Position Trending Tile.
This example illustrates the Financial Performance Analysis Tile.
This example illustrates the My Budget Tile.
My Budget Tile
This example illustrates the Controller's Key Metrics Tile.
Controllers Key Metrics Tile
