Kubernetes EngineKubernetes Engine (OKE) helps you define and create Kubernetes clusters to enable the deployment, scaling, and management of containerized applications.What's new Get Started Learn about OKE Review key concepts Prepare for OKE Product page Create Clusters Quick Create workflow Custom Create workflow Supported images and shapes Enhanced clusters Virtual nodes Access Clusters Set up access Add auth token to kubeconfig IAM and Kubernetes SSH to worker nodes Support Support Requests Create a service request Manage Clusters Edit clusters Edit nodes and node pools Encrypt Kubernetes secrets Configure DNS servers Manage Deployments Deploy sample Nginx app Pull images from Registry Create load balancers Set up storage Set up disaster recovery Observe Clusters Monitor clusters View work requests View audit logs View application logs Metrics Developer Tools Kubernetes Engine API Kubernetes Engine CLI SDKs and the CLI Cloud Shell Scale Clusters Add and remove node pools Scale node pools Autoscale node pools and pods Admission Controllers Supported admission controllers Pod security policies Upgrade Clusters Upgrade to new Kubernetes versions Supported Kubernetes versions Kubernetes support policy Troubleshooting and FAQs Troubleshooting Frequently Asked Questions Community Oracle Cloud Infrastructure blog Cloud infrastructure community forum AI solutions hub
