10 Setting Up Unified Inventory Management for Single Sign-On Authentication
This chapter provides instructions for setting up Oracle Communications Unified Inventory Management (UIM) for single sign-on (SSO) authentication.
UIM implements the single sign-on (SSO) authentication solution using SAML 2.0 authentication protocol from Identity Provider (IdP), which enables you to seamlessly access multiple applications without being prompted to authenticate for each application separately. The main advantage of SSO is that you are authenticated only once, which is when you log in to the first application; you are not required to authenticate again when you subsequently access different applications with the same (or lower) authentication level (as the first application) within the same web browser session.
UIM also supports the single logout (SLO) feature. If you access multiple applications using SSO within the same web browser session, and then if you log out of any one of the applications, you are logged out of all the applications.
This solution supports SSO authentication between UIM and Network Integrity applications.
Installing Required Software
Install and configure the following software that UIM requires for implementing SSO authentication:
External Lightweight Directory Access Protocol (LDAP) Server. Oracle recommends Oracle Internet Directory (OID) or Oracle Unified Directory (OUD) as the LDAP store external to the WebLogic Server.
For the list of software that can be optional if you use an Identity Provider other than OAM, see "Common Authentication Service".
- See "Configuring KeyCloak as Identity Provider for UIM, ATA, and Message Bus" for information on using KeyCloak as an Identity Provider for the UIM Cloud Native Environment..
- You can use any Identity Provider that supports SAML 2.0 protocol and OIDC or OAuth2.0 protocols.
Configuring SSO using SAML 2.0 Protocol from Identity Provider
You can use SAML 2.0 for enabling SSO in UIM. SSO allows you to log into applications using a single username and password combination.
For security concepts and definitions, see the Security Assertion Markup Language (SAML) section in Oracle Fusion Middleware Understanding Security for Oracle WebLogic Server.
Configuring SAML for SSO
To configure SAML for SSO:
- Create SAML Assertion Provider and SAML Authenticator.
- Enter General Information.
- Configure SAML Service Provider.
- Publish the Service Provider metadata.
- Register IdP in WebLogic.
- Update the Deployment Plan of UIM.
- Verify the SAML configuration.
Creating SAML Assertion Provider and SAML Authenticator
- Access the WebLogic Server Remote Console as administrator.
- Select Security Realm.
- Select myrealm.
- Select Authentication Providers, and then click New.
- Enter SAML2IdentityAsserter as Name, select
SAML2IdentityAsserter as Type, and then click OK.
The SAML2IdentityAsserter is displayed under the Authentication Providers table.
- On the Providers page, click New.
- Enter SAMLAuthenticator as Name, select SAMLAuthenticator as
The SAMLAuthenticator is displayed under the Authentication Providers table.
- Click Reorder.
- Select and reorder the providers in the following order:
- SAML2IdentityAsserter
- SAMLAuthenticator
- DefaultAuthenticator
- DefaultIdentityAsserter
- Click OK.
- Click SAMLAuthenticator.
- Select SUFFICIENT as Control Flag and then click Save.
- Return to the Providers page.
- Click DefaultAuthenticator.
- Commit your changes.
- Restart the server.
Specifying General Information
To specifiy General Information:
- Click Environment and then select Servers.
- Click the manager server (AdminServer) that has the Inventory application (for
example, ms1).
- In a clustered environment, perform these steps on ms1, ms2 and so on. In a standalone environment, perform these steps on the admin server.
- For all ms1, ms2, and Proxy servers, enable the Client Cert Proxy Enabled and
set the WebLogic Plug-In Enabled to
yesfor a proper SSL redirection. - Click Save.
- Click Federation Services and then select SAML 2.0 General.
- Define the site information and additional settings for the SAML assertion.
- Generate the service provider metadata file.
- Modify the General settings as showin the the table by replacing the information according to your requirement and the server.
- Click Save and commit your changes.
Table 10-1 Attribute and Values
| Attribute | Sample Value |
| Published Site URL |
https://<InventoryHostName>:<InventorySSLPort>/saml2 |
| Entity ID |
samlUIM Note: You can enter any identification value, as long it is unique in Identity Cloud Service and in your WebLogic Domain. |
| Recipient Check Enabled |
Deselected |
| Replicated Cache Enabled |
Configuring the SAML Service Provider
To configure the SAML service provider:
application (for example, ms1).
- Select Configuration, then Federation Services and then SAML 2.0 Service Provider.
- Select Enabled.
- Select Single Logout Enabled.
- Select Assertion Subject Timeout Check.
- Select POST as Preferred Binding.
- (Optional) Provide the list of Allowed redirect URIs to be used by Service Provider for after logout redirections.
- Enter https://<InventoryHost>:<InventorySSLPort>/Inventory/ as Default URL, and then click Save.
Publishing the Service Provider Metadata
To publish the service provider metadata:
example, ms1).
- In a clustered environment, the later steps must be performed on each managed server that has the Inventory application. (other than proxy and admin server)
- Select Configuration, Federation Services, and then SAML 2.0 General.
- Click Publish Meta Data.
The Publish SAML 2.0 Meta Data page appears.
- In the Path field, enter the full path and filename of the metadata file. For example, C:\mydomain\myserver\sppmeta.xml.
- Click OK.
Registering Identity Provider in WebLogic
To register a SAML Identity Provider in WebLogic:
- Upload the IdPMetadata.xml file from the Identity Provider to the server hosting WebLogic (for example, /path/to/metadata/file/IDCSMetadata.xml).
- Open the WebLogic Administration Server Remote Console as administrator.
- Click Security Realm and then select myrealm.
- Click Providers, and then select SAML2IdentityAsserter.
- Click Management, click New, and then select New Web Single Sign-On
Identity Provider Partner.
The Create a Web Single Sign-On Identity Provider Partner page appears.
This is required for enabling Identity Provider users with UIM group to access the UIM UI. See Configuring the SAML Authentication Provider for more information.
- In the Name field, enter WebSSO-IdP-Partner-1.
- In the Path field, enter the path to the XML file that contains the Identity Provider metadata.
- Click OK.
- Click the WebSSO-IdP-Partner-1 link.
- Ensure that the Identity Provider details appear in the Site Info and Single Sign-On Signing Certificate tabs.
- In the General tab, select Enabled, Virtual User, and Process Attributes check boxes.
- In the Redirect URIs field, enter /Inventory/*.
The WebLogic server displays a confirmation message.
- Sign out of the WebLogic server and close your browser.
Updating the Deployment Plan of Unified Inventory Management
Update the Plan.xml (Standalone) file or ClusterPlan.xml (Cluster) file depending on your environment, for the authentication to happen. These changes are applicable for a traditional UIM installation.
To update the deployment plan of UIM:
- Within <variable-definition>, override the value of the
existing logoutURL variable with the Identity Provider logout URL.
Replace /oracle/communications/platform/logout.jspx with the Identity Provider logout URL. For example, https://<WL_SP_hostname>:<WL_SP_port>/saml2/sp/slo/init.
<variable> <name>logoutURL</name> <value>IDP_LOGOUT_URL</value> </variable> - Update the <module-override> section of inv.war module name as
follows:
<module-override> <module-name>inv.war</module-name> <module-type>war</module-type> <module-descriptor external="false"> <root-element>weblogic-web-app</root-element> <uri>WEB-INF/weblogic.xml</uri> <variable-assignment> <name>cookie-path</name> <xpath>/weblogic-web-app/session-descriptor/cookie-path</xpath> <operation>remove</operation> </variable-assignment> </module-descriptor> <module-descriptor external="false"> <root-element>web-app</root-element> <uri>WEB-INF/web.xml</uri> <variable-assignment> <name>logoutURL</name> <xpath>/web-app/context-param[param-name="loginURL"]/param-value</xpath> <operation>replace</operation> </variable-assignment> <variable-assignment> <name>endURL</name> <xpath>/web-app/context-param[param-name="endUrl"]/param-value</xpath> <operation>replace</operation> </variable-assignment> </module-descriptor> </module-override>
Verifying SAML Configuration
To verify the SAML configuration:
- Enter the URL
http://<InventoryHostname>:<InventorySSLPort>/Inventory to
open the Inventory login page.
The login page of the Identity Provider appears.
- Enter the login credentials.
The UIM home page appears.
- After you log in, you can logout using the Logout option from the top right
corner of the page.
The login page of Identity Provider appears or a successful logout message appears, based on the configurations entered in Identity Provider.
- Close the browser or tab.
To register UIM in Identity Provider:
- Use Entity ID (for example, samlUIM).
This value must be same as the value provided in "Configuring the SAML Service Provider" under the SAML 2.0 General section within the Federation Services section. - Enter Assertion consumer URL as http://<InventoryHostname>:<InventorySSLPort>/saml2/sp/acs/post
Registering UIM in an Identity Provider
You can register UIM in an Identity Provider as a SAML application.
Instructions mentioned in this section are with reference to Identity Cloud Services (IDCS). In case you use a different Identity Provider, ensure that you follow the corresponding instructions of the Identity Provider while registering UIM.
Ensure SAML response contains the groups information as SAML 2.0 attributeStatement.
The attributes shared through SAML response must be in basic format for them to be considered.
To register a service provider (SP) with any Identity Provider, you can perform a manual configuration or import the SP Metadata (xml) file to the Identity Provider.
To import SP metadata files for creating SAML clients, use any Identity Provider other than IDCS. If you are using any other Identity Provider, and if it supports configuration using a service provider metadata file (for example: KeyCloak), you can publish the metadata file of UIM and use it to create a SAML client.
Manually Configuring UIM Details in Identity Provider
To manually configure UIM in an Identity Provider, for example IDCS:
- Access the IDCS console and log in as administrator.
- Navigate to the Domains and select the domain (Default domain) to add UIM as a SAML application.
- Click Add Application to register UIM as a SAML application.
- Select SAML Application and click Launch app catalog.
- Enter UIM Inventory Application as Name and UIM Inventory Application as SAML application as Description.
- Click Next.
- Enter Entity ID, for example: samlUIM. This should be same as the value provided in "Configuring the SAML Service Provider" under the SAML 2.0 General section under Federation Services.
- Enter http://InventoryHostname:InventoryPort/saml2/sp/acs/post as Assertion consumer URL.
- Select Unspecified as Name ID format.
- Select Username as Name ID value.
- Upload the SSL Certificate of UIM. This is required for SLO to work.
- Enter https://<WL_SP_hostname>:<WL_SP_port>/saml2/sp/slo as Single logout URL.
- Enter https://<WL_SP_hostname>:<WL_SP_port>/saml2/sp/slo as Logout response URL.
- Click + Additional attribute at the bottom-right corner
of the page.
- Enter Groups as Name.
The Groups attribute is case-sensitive. - Select User attribute as Type.
- Select Group membership as Type value.
- Select All groups as Condition.
- Click Finish.
- Click Activate to create the application (UIM Inventory Application).
- Click Activate application in the pop-up window.
- Click Download identity provider metadata for downloading the IdP metadata xml. For example, IDCSMetadata.xml.
- Click Users on the left side pane to assign users. Ensure the
desired users are added to your domain prior to this step.
- Click Assign groups for adding domain groups to the registered application.
- Choose the desired users from the pop-up window and click Assign.
- Click Groups on the left-side pane to assign groups.
Ensure uim-users group is created or added to your domain before performing this step.- Click Assign users for adding the domain users to the registered application.
- Choose uim-users from the pop-up window and click Assign.
Creating SAML2.0 Client in Identity Provider by Importing UIM Metadata (xml)
If your Identity Provider provides you an option to create SAML 2.0 client by importing the metadata file, you can use the published metadata file of UIM to create SAML2.0 client.
You can create SAML2.0 client in an identity provider other than IDCS.For traditional UIM, to publish the metadata file, verify the step on "Publishing the Service Provider Metadata".
For UIM cloud native, to publish metadata file, see "Publishing UIM Cloud Native Service Provider Metadata File" in UIM Cloud Native Deployment Guide.
Configuring WebLogic for Using Identity Provider for Authorization
You configure WebLogic to access the Identity Provider users in the Oracle Enterprise Manager (EM) console for authorization (in UIM).
For WebLogic server to authenticate users with the Identity Provider, the Identity Provider must be associated with an OAuth client that is registered with the Identity Provider. The OAuth client allows the provider access to the Identity Provider.
For authorization, the roles or groups information must be shared as basic format attributes in the SAML assertion response. For more information, see SAML 2.0 Basic Attribute Profile Required.
Updating the SSL.hostnameVerifier Property
The IDCS provider can access IDCS only if you update the SSL.hostnameVerifier property.
To update the SSL.hostnameVerifier property:
- Go to the WebLogic Administrator Remote Console and open Environment, Servers, your server (AdminServer), Configuration and then SSL.
- Open Advanced.
- Change Hostname Verification from BEA Hostname Verifier to Custom Hostname Verifier.
- Set Custom Hostname Verifier to weblogic.security.utils.SSLWLSWildcardHostnameVerifier.
- Click Save and then commit your changes.
- Start the Administration server and all Managed WebLogic servers.
Configuring Oracle Identity Cloud Integrator Provider
The Oracle Identity Cloud Integrator provider is an authentication and identity assertion provider that accesses users, groups, and Identity Provider scopes, and application roles stored in the IDCS Identity Provider.
Before you can configure the provider, you must obtain the required OAuth client information from IDCS Identity Provider. To do so, you create a trusted application in the Identity Provider. A trusted application in the Identity Provider is a type of custom application that can be accessed by multiple users and hosted in a secure and protected place (server) where the trusted application uses OAuth 2.0. Because you know where the application is hosted, you can treat that application as trusted. Creating the application in Identity Provider results in the provisioning of an OAuth client.
Creating the OAuth Client
To create OAuth client in the Identity Cloud Service console:
Perform similar steps for any Identity Provider.- Log into the Identity Cloud Service console as an administrator.
- Create a trusted application. See Adding a Trusted Application in Administering Oracle Identity Cloud Service.
The OAuth client can be used only within the specific tenant in which it was provisioned.
In the Add Trusted Application window:
- Enter a client name and a description (optional).
- Select Configure this application as a client now to configure the
authorization settings:
- Select only Client Credentials as the allowed grant type.
This setting is used when the authorization scope is limited to the protected resources under the control of the client or to the protected resources registered with the authorization server. The client presents the corresponding credentials to obtain an access token.
- Assign the client to the Identity Domain Administrator application role. To do so, select Grant the client access to Identity Cloud Service Admin APIs and then, in the pop-up window that appears, select Identity Domain Administrator.
Using the Identity Domain Administrator application role provides write access to the Oracle Identity Cloud Service user store. The WebLogic Server Oracle Identity Cloud Integrator provider does not support any update operations. Therefore, you must use the Identity Cloud Service Administration Console to modify the content of the user store.
- Go through the remaining pages in the wizard and click Finish.
- Note down the Client ID and Client Secret that appear when you create the
application.
You need these values when you configure the Oracle Identity Cloud Integrator provider. The attributes that you must provide while configuring the provider are:
- Tenant: Name of the primary tenant in the Identity Provider where you provisioned the OAuth client.
- ClientId: The OAuth client ID used to access the Identity Provider identity store.
- ClientSecret: The OAuth Client Secret (password) used to generate access tokens.
- Client tenant (Optional): Name of the OAuth client tenant in which the Client ID is available. This attribute is not required if the Client tenant is same as the primary tenant.
- Activate the application.
Configuring Identity Cloud Integrator Provider
To configure Identity Cloud Integrator Provider:
- Log into the WebLogic Server Administration Remote console.
- Select Security Realm in the Domain Structure pane.
- On the Summary of Security Realms page, select the name of the realm (for example,
myrealm) and click myrealm.
The Settings for myrealm page appears.
- On the Settings for Realm Name page, select Providers and then Authentication.
- To create a new Authentication Provider in the Authentication Providers table, click New.
- In the Create a New Authentication Provider page, enter the name of the authentication provider. For example, IDCSIntegrator.
- Select the OracleIdentityCloudIntegrator type of the authentication provider from the drop-down list and click OK.
- In the Authentication Providers table, click the newly created Oracle Identity Cloud Integrator IDCSIntegrator link.
- In the Settings for IDCSIntegrator page, select Sufficient from the drop-down list for Control Flag and click Save.
- Go to the Provider Specific page to configure the additional attributes for the security provider.
- Enter the values for the following fields and click Save:
- Host
- Port 443(default)
- select SSLEnabled
- Tenant
- Client Id
- Client Secret.
If the IDCS URL is idcs-abcde.identity.example.com, then IDCS host is identity.example.com and tenant name is idcs-abcde. Keep the default settings for the other sections of the page.
- Select Security Realm, myrealm, and then Authentication Providers.
- In the Authentication Providers table, click Reorder.
- In the Reorder Authentication Providers page, move IDCSIntegrator to the top and click OK.
- In the Authentication Providers table, click the DefaultAuthenticator link.
- In the Settings for DefaultAuthenticator page, select Sufficient from the drop-down list for Control Flag and click Save and commit your changes.
- Restart the Administration server.
Setting Up Trust between IDCS and WebLogic
To set up trust between IDCS and
WebLogic:
- Import the certificate in KSS store.
- Open the Administration Server node.
- Get the IDCS certificate as
follows:
echo -n | openssl s_client -showcerts -servername <IDCS_URL> -connect <IDCS_URL>:443|sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > /tmp/idcs_cert_chain.crt #sample echo -n | openssl s_client -showcerts -servername xyz.identity.oraclecloud.com -connect idcs-xyz.identity.oraclecloud.com:443|sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > /tmp/idcs_cert_chain.crt - Import the certificate and run the <ORACLE_HOME>/oracle_common/common/bin/wlst.sh file.
- Run the following
commands:
connect('weblogic','<admin_pwd>','t3://<WEBLOGIC_HOST>:7001') svc=getOpssService(name='KeyStoreService') svc.importKeyStoreCertificate(appStripe='system',name='trust',password='',alias='idcs_cert_chain',type='TrustedCertificate',filepath='/tmp/idcs_cert_chain.crt',keypassword='') syncKeyStores(appStripe='system',keystoreFormat='KSS') - Run
exit().
- Restart the Administration server and Managed servers.
Creating an Administrator User in IDCS Administration Console for WebLogic
You must create an Administrator user in IDCS because once the Managed servers are configured for SAML, the domain administrator user (usually, the weblogic user) cannot log into the Managed servers.
You must perform this procedure only if you use IDCS as Identity Provider.To create WebLogic Administrator user in IDCS for WebLogic JaxWS connection:
- In IDCS, go to the Groups tab and create the Administrators and sysmanager roles.
- Go to the Users tab and create a wls admin user, for example, weblogic and assign it to the Administrators and sysmanager groups.
- Restart all Managed servers.
Managing Group Memberships, Roles, and Accounts
To manage group memberships, roles, and accounts, you must update OPSS and libOVD to access IDCS.
The following procedure is required only if you use IDCS for user authorization.
Ensure that all servers are stopped (including Administration) before proceeding further.
To manage group memberships, roles, and accounts:
- Shutdown all servers that use WebLogic Server Administration Console.
You must use- kubectlpatch domain command for starting or stopping pods and not the WebLogic Server Administration Console. - Run the
following:
#Run the wlst.sh cd /u01/oracle/oracle_common/common/bin/ ./wlst.shNote:
This does not require a connection to the WebLogic Administration Server. - Read the domain as follows:
readDomain(<DOMAIN_HOME>) - Add the template as
follows:
addTemplate(<MIDDLEWARE_HOME>/oracle_common/common/templates/wls/oracle.opss_scim_template.jar")Note:
This step may throw a warning, which can be ignored. The addTemplate is deprecated. Use selectTemplate followed by loadTemplates instead of addTemplate. - Update the domain as follows:
updateDomain() - Close the domain as follows:
closeDomain() - Exit from the Administration server container using
exit(). - Start the Administration and Managed servers.
