7 Data Integration Products
This chapter describes the licensing information for Data Integration products.
For Oracle GoldenGate products licensing information, see Oracle GoldenGate Licensing Information.This chapter contains the following sections:
- Oracle Data Integrator Enterprise Edition
- Oracle Management Pack for Oracle Data Integrator
- Oracle Data Integrator for Big Data (DIBD)
- Oracle Data Integration Suite
- Oracle Enterprise Data Quality
- Oracle Application Adapters for Data Integration
- Oracle Application Adapters for Warehouse Builder
- Oracle Enterprise Metadata Management
Oracle Data Integrator Enterprise Edition is a software package for enabling scalable data integration in heterogeneous data environments.
Oracle Data Integrator Enterprise Edition includes the following components:
Oracle Data Integrator (ODI) (excluding those technologies separately licensed in the Oracle Application Adapters for Data Integration).
Oracle Warehouse Builder Enterprise ETL
To obtain high availability with Oracle Data Integrator Enterprise Edition, separate licenses to Oracle WebLogic Server Enterprise Edition and Oracle Coherence Enterprise Edition are required.
Prerequisite: A license to Oracle Database Enterprise Edition is a prerequisite to license and use Oracle Warehouse Builder Enterprise ETL.
Oracle Warehouse Builder Enterprise ETL extends the extraction, transformation, and loading (ETL) features separately available with Oracle Database and includes the following functionality:
Accessing sources and targets
Native support for heterogeneous databases, including the definition of new platform types, JDBC connectivity, knowledge modules, and code templates
Support for Exadata hybrid columnar compression
Transparent Data Encryption (TDE) support
External Table support for Data Pump imports and exports
External Table preprocessor support
Change Data Capture mappings in ET
Publishing and consuming web services, including integrating with process orchestration technologies such as Oracle BPEL Process Manager
Importing Cobol copybooks using the built-in wizard
Targeting XML files
Data Guard certification and failover support
Working with dimensional objects
Creating slowly changing dimensions, types 2 and 3
Storing data in OLAP cube-organized materialized views
Defining orphan management policies
Designing and executing ETL jobs
Right-time data warehousing utilizing queues and real-time mappings
Reusing and embedding mapping code with pluggable mappings
Specifying the load order of multiple targets in a single mapping
Partitioning and parallelizing updates to tables by utilizing the data chunking feature
Scheduling ETL jobs using the built-in Schedule interface
Using advanced process flows features (activity templates, use of the following activities: Assign, Set Status, For Loop, While Loop, Route, Notification, EJB, Java Class, and Webservice)
Designing mappings to handle complex types using the following operators: varray iterator, construct object, and expand object
Rapidly moving large amounts of data with transportable modules
Using spatial transformations and streams transformations
Compiled PL/SQL code generation
Bulk code templates for Oracle --> Oracle, SQL Server --> Oracle, and DB2 --> Oracle
Integrating with other products
Deploying metadata directly to Oracle Discoverer End User Layer
Deriving and deploying metadata to Oracle Business Intelligence Enterprise Edition
Administering Warehouse Builder and its metadata repository
Support for database failover
Managing environments, including promoting from development to test to production, using the multiple configurations functionality
Interactively analyzing metadata lineage and impact and automatically propagating metadata change using the Metadata Dependency Manager
Extending the metadata repository using the following: user-defined objects, user-defined associations, user-defined modules, creating icon sets and custom icons
Hosting the OWB design repository in an Oracle Real Application Clusters (Oracle RAC) environment (executing in an Oracle RAC environment does not require this license)
Operating multiple databases with OWB repositories from a single Oracle home
Restricted use: A license to Oracle Data Integrator Enterprise Edition includes a restricted use license to Oracle WebLogic Server Standard Edition. Use of Oracle WebLogic Server Standard Edition is restricted to running the Oracle Data Integrator Web Console. Any other use requires a full use license.
Third-Party Products and Details for Oracle Data Integrator
This section lists all the applicable commercial third party notices and/or licenses and all open source or other separately licensed third party notices and/or licenses, for Oracle Data Integrator, in the following sub-sections.
Commercial Software
Currently there are no commercial software products or components distributed in Oracle Data Integrator with the applicable licensing information.
Open Source or Other Separately Licensed Software
Required notices for open source or other separately licensed software products or components distributed in Oracle Data Integrator are identified in the following table, along with the applicable licensing information. Additional notices and/or licenses may be found in the included documentation or readme
files of the individual third party software.
The following release versions are associated with the third-party products in Oracle Data Integrator:
11.1.1.9.0
12.2.1.2.0
12.2.1.3.0
12.2.1.4.0
Table 7-1 Third-Party Notices and/or Licenses and Open Source or Other Separately Licensed Software in Oracle Data Integrator
Provider | Component(s) | Release Versions | Licensing Information |
Apache |
Batik SVG toolkit 1.10 |
12.2.1.4.0 |
For a copy of the license, see Apache License Version 2. |
Apache |
Batik SVG toolkit 1.11 |
12.2.1.4.0 |
Batik License Batik is licensed according to the Apache License, Version 2.0, the text of which is included below. For a copy of the license, see Apache License Version 2. Copyright 1999-2018 The Apache Software Foundation This product includes software developed at The Apache Software Foundation ( This software contains code from the World Wide Web Consortium (W3C) for the Document Object Model API (DOM API) and SVG Document Type Definition (DTD). This software contains code from the International Organisation for Standardization for the definition of character entities used in the software's documentation. This product includes images from the Tango Desktop Project ( This product includes images from the Pasodoble Icon Theme ( |
Apache |
HTTP Client 3.1 |
12.2.1.2.0 12.2.1.3.0 12.2.1.4.0 |
Apache |
BSF (java Bean Scripting Framework 2.4.0 |
12.2.1.4.0 |
Copyright © 2002-2011 The Apache Software Foundation. All Rights Reserved. For a copy of the license, see Apache License Version 2. |
Apache |
Commons Collections 3.2.2 |
12.2.1.2.0 12.2.1.3.0 |
Apache Commons Collections Copyright 2001-2015 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2 |
Apache |
12.2.1.4.0 |
Apache |
Commons Collections 4.2 |
12.2.1.4.0 |
Apache Commons Collections Copyright 2001-2018 The Apache Software Foundation For a copy of the license, see Apache License Version 2 |
Apache |
Commons FileUpload 1.3.3 |
12.2.1.4.0 |
For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
Commons FileUpload 1.4 |
12.2.1.4.0 |
Copyright 2002-2018 The Apache Software Foundation This product includes software developed at The Apache Software Foundation ( For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
Commons Logging 1.2-0548efb |
12.2.1.4.0 |
Apache Commons Logging Copyright 2003-2016 The Apache Software Foundation This product includes software developed at The Apache Software Foundation ( For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
Commons VFS 2.2 |
12.2.1.4.0 |
Source URL: https://github.com/apache/commons-vfs/tree/commons-vfs2-project-2.2 Apache License URL: For a copy of the license, see Apache License Version 2 Copyright URL: Apache Commons VFS Copyright 2002-2017 The Apache Software Foundation This product includes software developed at The Apache Software Foundation ( |
Apache |
Commons Discovery 0.5 |
12.2.1.4.0 |
Apache |
commons-lang3 3.8.1 |
12.2.1.4.0 |
Apache Commons Lang Copyright 2001-2018 The Apache Software Foundation This product includes software developed at The Apache Software Foundation For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
commons-net 3.5 |
12.2.1.4.0 |
Apache Commons Lang Copyright 2001-2016 The Apache Software Foundation This product includes software developed at The Apache Software Foundation For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
Groovy 2.4.6 2.4.11 |
Apache |
Groovy 2.4.15 |
12.2.1.4.0 |
Apache |
Log4J 2.11.1 |
12.2.1.4.0 |
Apache log4j Copyright 1999-2017 The Apache Software Foundation All rights reserved. This product is licensed to you under the Apache License, Version 2.0 (the "License"). You may not use this product except in compliance with the License. You may obtain a copy of the License at: For more information on this license and/or for a copy of the license, see Apache License Version 2. Modules: log4j-1.2-api log4j-api-java9 log4j-api log4j-appserver log4j-bom log4j-cassandra log4j-core-its log4j-core-java9 log4j-core log4j-couchdb log4j-distribution log4j-flume-ng log4j-iostreams log4j-jcl log4j-jdbc-dbcp2 log4j-jmx-gui log4j-jpa log4j-jul log4j-liquibase log4j-mongodb2 log4j-mongodb3 log4j-osgi log4j-perf log4j-samples log4j-slf4j-impl log4j-slf4j18-impl log4j-taglib log4j-to-slf4j log4j-web |
Apache |
oro 2.0.8 |
12.2.1.4.0 |
Copyright© 2017, the Apache Software Foundation. Licensed under the Apache License, Version 2.0 Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at For a copy of the license, see Apache License Version 2. |
Apache |
HttpCore 4.4.10 |
12.2.1.4.0 |
Licensed to the Apache Software Foundation (ASF) under one or more contributor license agreements. See the NOTICE file distributed with this work for additional information regarding copyright ownership. The ASF licenses this file to you under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License. For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
Apache HttpComponents HttpClient 4.5.6 |
12.2.1.4.0 |
Copyright © 1999-2017 The Apache Software Foundation. This product includes software developed at The Apache Software Foundation ( For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
SVN (Subversion) 1.8.10 |
Apache |
XMLSchema 1.4.7 |
12.2.1.4.0 |
Apache WebServices - XmlSchema Copyright 2004-2010 The Apache Software Foundation This product includes software developed at The Apache Software Foundation ( Portions Copyright 2006 International Business Machines Corp. For a copy of the license, see Apache License Version 2. |
JCraft |
JSch 0.1.44 |
Copyright © 2002–2010 Atsuhiko Yamanaka, JCraft, Inc. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
THIS SOFTWARE IS PROVIDED "AS IS", AND ANY EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL JCRAFT, INC. OR ANY CONTRIBUTORS TO THIS SOFTWARE BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. |
JCraft |
JSch 0.1.54 |
12.2.1.4.0 |
Copyright © 2002–2015 Atsuhiko Yamanaka, JCraft, Inc. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
Eclipse Foundation |
JGit 3.6.2 |
Eclipse Distribution License - v 1.0 Copyright (c) 2007, Eclipse Foundation, Inc. and its licensors. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. Neither the name of the Eclipse Foundation, Inc. nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. |
JGit 5.2.0 |
12.2.1.4.0 |
FasterXML, LLC |
jackson-core 2.9.9 |
12.2.1.4.0 |
Copyright (c) 2007- Tatu Saloranta, For a copy of the license, see Apache License Version 2. |
GSON 2.6.2 |
Copyright 2008 Google Inc. Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License. For a copy of the license, see Apache License Version 2. |
Google Guava 27.1 |
12.2.1.4.0 |
Copyright (C) 2008 The Guava Authors Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License. Common annotation types. This package is a part of the open-source <a href=" For more information on this license and/or for a copy of the license, see Apache License Version 2. Modules: guava-bom guava-gwt guava-testlib guava-tests guava refactorings util |
HSQL Development Group |
HSQLDB 2.4.1 |
12.2.1.4.0 |
Copyright (c) 2001-2016, The HSQL Development Group All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL HSQL DEVELOPMENT GROUP, HSQLDB.ORG, OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. For work originally developed by the Hypersonic SQL Group: Copyright (c) 1995-2000 by the Hypersonic SQL Group. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE HYPERSONIC SQL GROUP, OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. This software consists of voluntary contributions made by many individuals on behalf of the Hypersonic SQL Group. |
JGoodies |
JGoodies Binding 2.13.0 |
12.2.1.4.0 |
Copyright (c) 2002-2015 JGoodies Software GmbH. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS", AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. |
JGoodies Karsten Lentzsch |
JGoodies Forms 1.8.0 |
12.2.1.4.0 |
Copyright (c) 2002-2014 JGoodies Software GmbH. All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
Jayway AB |
JsonPath 2.2 |
Jython |
Jython 2.7.1 |
12.2.1.4.0 |
The Jython License For more information on this license and/or for a copy of the license, see Jython License. |
Object Refinery Limted and Contributors |
JFreeChart 1.5.0 |
12.2.1.4.0 |
(C)opyright 2000-2016, by Object Refinery Limited and Contributors. JFreeChart is licensed under the terms of the GNU Lesser General Public Licence (LGPL). A copy of the licence is included in the distribution. For more information on this license and/or for a copy of the license, see GNU LESSER GENERAL PUBLIC LICENSE (Version 2.1). |
Pivotal, Inc. |
Spring Framework 5.1.3 |
12.2.1.4.0 |
Spring 5.1.3.RELEASE is licensed under Apache 2.0. For a copy of the license, see Apache License Version 2. |
QOS.ch |
SLF4J 1.7.26 |
12.2.1.4.0 |
Copyright (c) 2004-2017 QOS.ch All rights reserved. Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT OF THIRD PARTY RIGHTS. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. For a copy of the license, see Apache License Version 2. |
The Apache Software Foundation |
Commons Beanutils 1.9.3 |
12.2.1.4.0 |
Copyright 2000-2016 The Apache Software Foundation For a copy of the license, see Apache License Version 2. |
Parent topic: Oracle Data Integrator Enterprise Edition
Management Pack for Oracle Data Integrator provides a consolidated view of a user's entire Oracle Data Integrator (ODI) infrastructure enabling users to monitor and manage the ODI components centrally.
Prerequisite: A license to Data Integrator Enterprise Edition or Data Integrator for Oracle Business Intelligence or Oracle Data Integrator Enterprise Edition for Oracle Applications is a prerequisite to license and use Oracle Management Pack for Oracle Data Integrator.
Parent topic: Data Integration Products
Oracle Data Integrator for Big Data (DIBD) includes the following capabilities for use with certain Apache Hadoop technologies, as follows:
Code generation architecture using;
Apache Cassandra Technology
Apache Cassandra Knowledge Modules
Apache Kafka Technology
Apache Kafka Knowledge Modules
Apache Spark Technology
Apache Spark Knowledge Modules
Apache Pig Technology
Apache Pig Knowledge Modules
Execution of ODIEE Scenarios using the Apache Oozie workflow manager.
DIBD is compatible with, but does not include, the above-listed Apache programs. You must separately obtain the Apache programs you wish to use with DIBD.
Restricted Use: A license to Oracle Data Integrator for Big Data includes a restricted use license to Oracle Data Integrator Enterprise Edition restricted to the Oracle Data Integrator component. Use of Oracle Data Integrator component of Oracle Data Integrator Enterprise Edition is restricted to be used when the data transformations are executed in Big Data environments.
Restricted use: A license to Oracle Data Integrator for Big Data includes a restricted use license to Oracle WebLogic Server Standard Edition. Use of Oracle WebLogic Server Standard Edition is restricted to running the Oracle Data Integrator Web Console component of Oracle Data Integrator Enterprise Edition only.
Oracle Data Integration Suite (ODI Suite) is a software bundle for enabling scalable, highly-accessible data integration in any heterogeneous data environment.
Oracle Data Integration Suite includes:
Hyperion Data Relationship Management (up to maximum of 2,000 records per processor)
Restricted use: A license to Oracle Data Integration Suite includes restricted-use licenses to the following products:
Oracle WebLogic Suite. Use of Oracle WebLogic Suite is restricted to hosting ODI Suite components including run-time components to provide a Java run-time environment as well as configuration and administration components used for the setup and management of these run-time components. Any other use of Oracle WebLogic Suite requires a full use license.
Oracle BPEL Process Manager. Oracle BPEL Process Manager may only be used with Oracle Data Integrator and/or Hyperion Data Relationship Management as endpoints.
Oracle Service Bus. Oracle Service Bus may only be used with Oracle Data Integrator and/or Hyperion Data Relationship Management as endpoints.
Oracle Enterprise Data Quality (EDQ) technology includes the following separately licensed products:
Oracle Enterprise Data Quality Profiling for Data Integration
Oracle Enterprise Data Quality Audit and Dashboard for Data Integration
Oracle Enterprise Data Quality Batch Processing for Data Integration
Oracle Enterprise Data Quality Real-time Processing for Data Integration
Oracle Enterprise Data Quality Address Verification Server for Data Integration
Restricted use: A license to any of the EDQ products listed above includes a restricted-use license to WebLogic Server Standard Edition (WLSSE). Use of WLSSE is restricted to hosting Java application logic that is distributed as part of the EDQ products listed above. Any modifications implemented as Java programs, which include Java programs that produce html interfaces or Java business logic, are not permitted. The restricted-use license to WLSSE includes use of the Oracle Application Development Framework subcomponent of the TopLink and ADF component. Any other use of WLSSE requires a full use license.
- Oracle Enterprise Data Quality Audit and Dashboard for Data Integration
- Oracle Enterprise Data Quality Batch Processing for Data Integration
- Oracle Enterprise Data Quality Real-time Processing for Data Integration
- Oracle Enterprise Data Quality Address Verification Server for Data Integration
- Third-Party Products and Details for Oracle Enterprise Data Quality
Prerequisite: A license to Oracle Enterprise Data Quality Profiling for Data Integration is a prerequisite to license and use Oracle Enterprise Data Quality Audit and Dashboard for Data Integration.
Parent topic: Oracle Enterprise Data Quality
Prerequisite: A license to Oracle Enterprise Data Quality Profiling for Data Integration or Oracle Enterprise Data Quality Profile and Audit is a prerequisite to license and use Oracle Enterprise Data Quality Batch Processing for Data Integration.
Prerequisite: A license to Oracle Enterprise Data Quality Batch Processing for Data Integration is a prerequisite to license and use Oracle Enterprise Data Quality Real-time Processing for Data Integration.
Prerequisite: A subscription to address data packs obtained from Oracle's partner, Loqate Inc., is required to license and use Oracle Enterprise Data Quality Address Verification Server for Data Integration.
Prerequisite: A license to Oracle Enterprise Data Quality Batch Processing for Data Integration is a prerequisite to license and use Oracle Enterprise Data Quality Address Verification Server for Data Integration.
This section lists all the applicable commercial third party notices and/or licenses and all open source or other separately licensed third party notices and/or licenses, for the following Oracle Enterprise Data Quality:
Commercial Software
Currently there are no commercial software products or components distributed in Oracle Enterprise Data Quality Audit and Dashboard for Data Integration with the applicable licensing information.
Required notices for open source or other separately licensed software products or components distributed in Oracle Enterprise Data Quality Audit and Dashboard for Data Integration are identified in the following table, along with the applicable licensing information. Additional notices and/or licenses may be found in the included documentation or readme
The following release versions are associated with the third-party products in Oracle Enterprise Data Quality:
11.1.1.9.0
12.2.1.2.0
12.2.1.3.0
12.2.1.4.0
Table 7-2 Third-Party Notices and/or Licenses and Open Source or Other Separately Licensed Software in Oracle Enterprise Data Quality
ANTLR |
Antlr 3.5.2 |
This product was build using ANTLR, which was provided to Oracle under the following terms: Copyright (c) 2013 Terence Parr All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
Apache |
ActiveMQ 5.4.2, 5.13.2 |
12.2.1.2.0 |
Apache |
ActiveMQ 5.13.2 |
12.2.1.3.0 |
Apache |
commons-lang 3.4, 3.5 |
Apache |
commons-pool 2.6.1 |
12.2.1.4.0 |
Copyright 2001-2019 The Apache Software Foundation This product includes software developed by The Apache Software Foundation For more information on this license and/or for a copy of the license, see Apache License Version 2. |
Apache |
12.2.1.4.0 |
Copyright 2001-2018 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache |
Apache Commons DBCP |
Copyright © 2001–2010 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache |
Commons DBCP 2.5.0 |
12.2.1.4.0 |
Apache Commons DBCP Copyright 2001-2018 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache |
Apache Commons IO |
12.2.1.2.0 |
Apache Commons IO Copyright © 2001–2008 The Apache Software Foundation For a copy of the license, see Apache License Version 2. |
Apache |
Apache Commons Lang |
12.2.1.2.0 |
Apache Commons Lang Copyright © 2001–2011 The Apache Software Foundation For a copy of the license, see Apache License Version 2. |
Apache |
12.2.1.4.0 |
Apache Commons Logging Copyright 2003-2016 The Apache Software Foundation This product includes software developed at The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache Commons Logging 1.1.3 |
Apache Commons Logging Copyright © 2003–2013 The Apache Software Foundation This product includes software developed at The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache Commons Logging 1.1 1.1.1 |
12.2.1.3.0 |
NOTICE file corresponding to the section 4d of The Apache License, Version 2.0, in this case for Commons Logging Commons Logging Copyright 2001-2007 The Apache Software Foundation This product includes/uses software(s) developed by 'an unknown organization' - Unnamed - avalon-framework:avalon-framework:jar:4.1.3 - Unnamed - log4j:log4j:jar:1.2.12 - Unnamed - logkit:logkit:jar:1.0.1 For a copy of the license, see Apache License Version 2. |
Apache Commons Logging 1.1.1 |
12.2.1.3.0 |
Apache |
Commons Pool 1.6 |
12.2.1.3.0 |
Apache |
Apache Derby |
Copyright 2004-2008 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( Portions of Derby were originally developed by International Business Machines Corporation and are licensed to the Apache Software Foundation under the "Software Grant and Corporate Contribution License Agreement", informally known as the "Derby CLA". The following copyright notice(s) were affixed to portions of the code with which this file is now or was at one time distributed and are placed here unaltered. (C) Copyright 1997,2004 International Business Machines Corporation. All rights reserved. (C) Copyright IBM Corp. 2003. The portion of the function Tests under 'nist' was originally developed by the National Institute of Standards and Technology (NIST), an agency of the United States Department of Commerce, and adapted by International Business Machines Corporation in accordance with the NIST Software Acknowledgment and Redistribution document at For a copy of the license, see Apache Derby License. |
Apache |
Apache Derby 10.9.1 |
12.2.1.3.0 |
Apache |
Apache Derby 10.14.1.0 |
12.2.1.4.0 |
Copyright 2004-2018 The Apache Software Foundation For a copy of the license, see Apache License Version 2 Modules: engine net client tools optionaltools war derbyLocale_cs derbyLocale_de_DE derbyLocale_es derbyLocale_fr derbyLocale_hu derbyLocale_it derbyLocale_ja_JP derbyLocale_ko_KR derbyLocale_pl derbyLocale_pt_BR derbyLocale_ru derbyLocale_zh_CN derbyLocale_zh_TW |
Apache |
Derby 10.14.2.0 |
12.2.1.4.0 |
Apache |
Apache FOP 1.1 |
Apache |
Apache FTP Server |
Copyright 2003-2010 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache |
Apache FTP Server 1.1.1 |
12.2.1.4.0 |
Apache |
FTPServer 1.1.1 |
12.2.1.4.0 |
Copyright 2003-2011 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( This product includes/uses software, AOP alliance ( This product includes/uses software, Log4j ( This product includes/uses software, Apache Ftplet API ( This product includes/uses software, Apache FtpServer Core ( This product includes/uses software, Apache MINA Core ( This product includes/uses software, JCL 1.1.1 implemented over SLF4J ( This product includes/uses software, SLF4J API Module ( This product includes/uses software, SLF4J LOG4J-12 Binding ( This product includes/uses software, Spring Framework: Beans ( This product includes/uses software, Spring Framework: Context ( This product includes/uses software, Spring Framework: Core ( For a copy of the license, see Apache License Version 2. |
Apache |
Apache Jakarta Commons HttpClient 3.1 |
Copyright 1999-2007 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache |
Apache Commons Pool |
Copyright 2001-2010 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache |
HttpComponents HttpClient 4.5.1 |
Apache |
Apache Lucene |
For a copy of the license, see Apache Lucene License. |
Apache |
Mina 2.0.19 |
12.2.1.4.0 |
Copyright 2007-2012 The Apache Software Foundation. This product includes software developed at The Apache Software Foundation ( For a copy of the license, see Apache MINA SSHD License. |
Apache |
Apache Mina SSHD 0.2.0 |
12.2.1.2.0 |
For a copy of the license, seeApache MINA SSHD License. |
Apache |
Apache Mina SSHD 0.8.0 |
For a copy of the license, see Apache MINA SSHD 06 License. |
Apache |
Apache POI 3.8 |
Apache POI Copyright 2009 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( This product contains the DOM4J library ( Copyright 2001-2005 (C) MetaStuff, Ltd. All Rights Reserved. This product contains parts that were originally based on software from BEA. Copyright (c) 2000-2003, BEA Systems, This product contains W3C XML Schema documents. Copyright 2001-2003 (c) World Wide Web Consortium (Massachusetts Institute of Technology, European Research Consortium for Informatics and Mathematics, Keio University) This product contains the Piccolo XML Parser for Java ( Copyright 2002 Yuval Oren. This product contains the chunks_parse_cmds.tbl file from the vsdump program. Copyright (C) 2006-2007 Valek Filippov ( For a copy of the license, see Apache License Version 2. |
Apache |
Apache POI 3.17 |
12.2.1.4.0 |
This product includes software developed by The Apache Software Foundation ( Portions of this software were originally based on the following: software copyright (c) 2000-2003, BEA Systems, <http://www.bea.com/>. Aside from contributions to the Apache XMLBeans project, this software also includes:
Apache |
Batik SVG Toolkit 1.11 |
12.2.1.4.0 |
Apache |
Commons Codec 1.4 |
12.2.1.2.0 |
Apache Commons Codec Copyright © 2002–2009 The Apache Software Foundation Copyright © 2002 Kevin Atkinson ( For a copy of the license, see Apache License Version 2. |
Apache |
Commons Codec 1.5 |
Apache Commons Codec Copyright 2002-2011 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( src/test/org/apache/commons/codec/language/DoubleMetaphoneTest.java contains test data from Copyright (C) 2002 Kevin Atkinson (kevina@gnu.org). Verbatim copying and distribution of this entire article is permitted in any medium, provided this notice is preserved. For a copy of the license, see Apache License Version 2. |
Apache |
Groovy 2.4.6 |
12.2.1.3.0 |
NOTICE file corresponding to the section 4 d of the Apache License, Version 2.0, in this case for the Groovy Language distribution. Groovy Language Copyright 2003-2013 The respective authors and developers Developers and Contributors are listed in the project POM file and Gradle build file This product includes software developed by The Groovy community ( For a copy of the license, see Apache License Version 2. |
Apache |
Groovy 2.4.15 |
12.2.1.4.0 |
Apache License, Version 2.0 FoundationProjectsPeopleGet InvolvedDownloadSupport ApacheHome » Licenses For a copy of the license, see Apache License Version 2. |
Apache |
Groovy 1.8, 2.4.2 |
12.2.1.2.0 |
Apache |
httpmime 4.5.1 |
Apache |
Jakarta Commons DBCP 1.3 |
12.2.1.3.0 |
NOTICE file: Apache Commons DBCP Copyright 2001-2010 The Apache Software Foundation This product includes software developed by The Apache Software Foundation ( For a copy of the license, see Apache License Version 2. |
Apache |
Log4j 1.2.9 |
Apache |
XMLBeans 3.1.0 |
12.2.1.4.0 |
includes:
Codehaus |
Jaxen 1.1.6 |
Copyright © 2003–2006 The Werken Company All Rights Reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
FasterXML, LLC |
Classmate 0.8.0 |
You may not use the identified files except in compliance with the Apache License, Version 2.0 (the "License.") You may obtain a copy of the License at: Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License. For more information on this license and/or for a copy of the license, see Apache License Version 2. |
FasterXML, LLC |
Classmate 1.3.1 |
12.2.1.4.0 |
Hibernate |
hibernate-validator 5.3.6.Final |
12.2.1.4.0 |
IBM |
ICU 4.2.1 |
For a copy of the license, see ICU License. |
IBM |
ICU4J 63.1 |
12.2.1.4.0 |
Copyright © 1991-2018 Unicode, Inc. All rights reserved. For a copy of the license, see ICU4J License (V58 and Later). |
Jason Hunter & Brett McLaughlin |
JDOM 1.1 |
Copyright © 2000–2004 Jason Hunter & Brett McLaughlin All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
In addition, we request (but do not require) that you include in the end-user documentation provided with the redistribution and/or in the software itself an acknowledgement equivalent to the following: "This product includes software developed by the JDOM Project ( Alternatively, the acknowledgment may be graphical using the logos available at THIS SOFTWARE IS PROVIDED "AS IS", AND ANY EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE JDOM AUTHORS OR THE PROJECT CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. This software consists of voluntary contributions made by many individuals on behalf of the JDOM Project and was originally created by Jason Hunter |
Mozilla |
Rhino (Java Script Engine) |
For a copy of the license, see Mozilla Public License Version 1. |
Pivotal, Inc. |
12.2.1.4.0 |
Copyright (c) 2002-2017 Pivotal, Inc. This product is licensed to you under the Apache License, Version 2.0 (the "License"). You may not use this product except in compliance with the License. For a copy of the license, see Apache License Version 2. |
PostgreSQL Global Development Group |
PostgreSQL JDBC driver 9.2-1002 |
Copyright (c) 1997-2010, PostgreSQL Global Development Group All rights reserved. Redistribution and use in source and binary forms, with or without modification, are
PostgreSQL JDBC driver 42.2.5 |
12.2.1.4.0 |
The PostgreSQL JDBC Driver is distributed under the BSD-2-Clause License. Copyright (c) 1997, PostgreSQL Global Development Group All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
Red Hat |
Hibernate Validator RI (JSR 303) 5.0.0.Final |
12.2.1.3.0 |
QOS.ch |
SLF4J 1.7.25 |
12.2.1.4.0 |
Copyright © 2004–2017 QOS.ch All rights reserved. Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. |
SLF4J |
SLF4J 1.5.10 |
Copyright © 2004–2008 QOS.ch All rights reserved. Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. |
SLF4J |
Simple Logging Façade for Java (SLF4J) 1.7.21 |
Copyright (c) 2004-2013 QOS.ch All rights reserved. Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software. THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. |
SpringSource |
Spring 2.5.6 SEC02 |
12.2.1.2.0 |
SpringSource |
Spring Framework 4.3.3.RELEASE |
Spring Framework 3.2.2.RELEASE Copyright (c) 2002-2013 SpringSource, a division of VMware, Inc. This product is licensed to you under the Apache License, Version 2.0 (the "License"). You may not use this product except in compliance with the License. This product may include a number of subcomponents with separate copyright notices and license terms. Your use of the source code for these subcomponents is subject to the terms and conditions of the subcomponent's license, as noted in the license.txt file. For a copy of the license, see Apache License Version 2. |
TMate |
SVNKit 1.10.0 |
12.2.1.4.0 |
Copyright (c) 2010 Terence Parr All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
ActiveMQ 5.15.3 |
12.2.1.4.0 |
ActiveMQ 5.15.8 |
12.2.1.4.0 |
Oracle Application Adapters for Data Integration assist for reverse-engineering metadata and extracting bulk data from the enterprise resource planning (ERP) software applications listed below in this section.
Restricted use: Each Application Adapter for Data Integration is licensed separately. Use of Application Adapter(s) for Data Integration is restricted for use with Oracle Data Integrator Enterprise Edition and the Oracle Data Integrator component.
Application Adapters for Data Integration are available for PeopleSoft, JD Edwards World, JD Edwards Enterprise One, E-Business Suite, Siebel, SAP Applications and SAP Business Warehouse Applications.
Table 7-3 Included components for Application Adapters for Data Integration
Oracle Application Adapters for Data Integration: | Included Components: |
Application Adapter for Data Integration for PeopleSoft |
Reverse-engineering Knowledge Module PeopleSoft Oracle Reverse-engineering Knowledge Module PeopleSoft MSSQL |
Application Adapter for Data Integration for JD Edwards World |
Reverse-engineering Knowledge Module JDE World Reverse-engineering Knowledge Module JDE World (JDE World JDBC Driver) Integration Knowledge Module JDE World Control Append |
Application Adapter for Data Integration for JD Edwards Enterprise One |
Reverse- Engineering Knowledge Module JDE Enterprise One Oracle Reverse-Engineering Knowledge Module JDE Enterprise One SQL Server Reverse-engineering Knowledge Module JDE Enterprise One DB2 UDB Reverse-engineering Knowledge Module JDE Enterprise One DB2 AS400 Integration Knowledge Module JDE Enterprise One Control Append (UBE) |
Application Adapter for Data Integration for Siebel |
Integration Knowledge Module SQL to Siebel Append (EIM) Loading Knowledge Module Siebel to SQL (EIM) Reverse-engineering Knowledge Module Siebel Oracle Reverse-engineering Knowledge Module Siebel EIM Oracle Reverse-engineering Knowledge Module Siebel MSSQL Reverse-engineering Knowledge Module Siebel EIM MSSQL |
Application Adapter for Data Integration for E-Business Suite |
Integration Knowledge Module E-Business Suite (Open Interface) Reverse-engineering Knowledge Module E-Business Suite |
Application Adapter for Data Integration for SAP Applications |
Reverse-engineering Knowledge Module SAP ERP Connection Test Loading Knowledge Module SAP ERP to Oracle (SQLLDR) Loading Knowledge Module SAP ERP to SQL Reverse-engineering Knowledge Module SAP ERP |
Application Adapter for Data Integration for SAP Business Warehouse |
Reverse-engineering Knowledge Module SAP BW Loading Knowledge Module SAP BW to Oracle (SQLLDR) Loading Knowledge Module SAP to SQL |
Each Application Adapter for Warehouse Builder is licensed separately. Any use of Application Adapters for Warehouse Builder, including users constructing their own application adapters for Warehouse Builder using Oracle-documented APIs, requires a full use license to Oracle Data Integrator Enterprise Edition.
Application Adapters for Warehouse Builder are available for PeopleSoft, SAP, Siebel, and E-Business Suite.
Oracle Enterprise Metadata Management is a software package for metadata management of multi-vendor environments and support for data governance.
