2 Installation Notes and Issues
The following items affect Oracle Hardware Management Pack installation.
- Check the State of Modules If Your System Is Running Oracle Linux Fault Management Software On Oracle Linux
- Unix Installer Issue (6977584)
- Error Reported When Launching Installer on a Solaris System (6982393)
- Running Installer on Solaris With SUNWCreq Cluster Fails (6982718)
- Oracle Solaris OS Servers with SUNWipmi Installed Cannot Complete the Install (7070692)
- Unable to Launch Installer in GUI Mode on Oracle Linux 6 (7129501)
- Installing the QLogic Support on Linux Takes a Long Time (7115215)
- Error returned as Available space in Summary Screen (15820240)
- Oracle Linux FMA Installation Can Fail When Using Either Anaconda or Oracle System Assistant to Install the OS (19182604)
- Defaults for mcelog in Oracle Linux 7 Prevent Oracle Linux FMA From Working Properly (19731891)
- Uninstall Location Changed For Oracle Hardware Management Pack 2.3.2.2 and Later (23299302)
- Manually Enable SNMP Fault Trap Proxy Port If SELinux was Disabled During Management Agent Installation (27805017, 27824302)
- Host-to-ILOM Interconnect Feature Might be Left in Disabled State When Oracle Solaris Automated Installer is Used (18652144, 18696723)
- Oracle VM 3.2 and 3.3 Oracle HMP Installation Packages (18131790)
- Might Need to Reboot Oracle Solaris 11.1 System After Oracle HMP Installation (18231930)
- Invalid Publisher in Package Repository Causes Installation Failure on Oracle Solaris System (18262997)
- Installing in Oracle Solaris Zones
- Do Not Use install.bin -uninstall Command to Uninstall Oracle Hardware Management Pack (15777347)
- Hardware Management Pack Installer GUI Requires libXtst.i686 for an Oracle Linux 6.1 System (15766013)
- Install glibc.i686 for Oracle Enterprise Linux 6 Before Running the Installer (15715967)
- Red Hat Installation Dependencies
- Install Path Issues
- Oracle Hardware Management Pack Uninstaller Does Not Remove hwmgmtd and itpconfig Components in Solaris 11 (20163489)
- The Oracle Hardware Management Pack Version 2.4.4 Installer Is Missing the Option to Install the Linux FMA Component (28066798, 28550331)
- SELinux Error When Installing the Management Agent on a System Running Oracle VM 3.4.5 (28550305)
- Oracle Hardware Management Pack Installer Error: Installer User Interface Mode Not Supported (28031522, 28096927)
- Oracle Solaris 10 Patches Needed for Oracle HMP 2.4 (34859266, 34859278)
- Oracle Hardware Management Pack 2.4.9.0 Installation
