Taking a Snapshot: Oracle ILOM SP State
Caution:
The purpose of the Oracle ILOM Snapshot feature is to collect data for use by Oracle Services personnel to diagnose system problems. Customers should not run this utility unless requested to do so by Oracle Services personnel.The Snapshot feature in Oracle ILOM enables you to collect information about the current state of the service processor (SP). This information can include environmental data, logs, and information about field-replaceable units installed on the server. In addition, you can use Snapshot to run diagnostics on the host and capture the diagnostics log files.
The output from Snapshot is saved as a standard zip file or an encrypted zip file to a location you specify.
To use the Snapshot feature, see the following procedures:
