Configuring Local User Accounts
System administrators can create and maintain up to 10 local user accounts in Oracle ILOM. For instructions for using configurable properties in Oracle ILOM to create or maintain local user accounts, see the following tables:
For SPARC platforms, such as the M-series servers, system administrators can create and maintain up to 60 local user accounts. To determine the maximum number of user accounts supported, click the More details... link in the ILOM Administration → User Management → User Account page in the web interface.- Table 3-8 Create User Account and Assign User Roles
- Table 3-9 View, Modify,
or Remove User Account
Deleting a user account will not automatically terminate any active user sessions remaining in Oracle ILOM for that user. To manage user sessions, see Manage User Authenticated Sessions per Managed Device.
User Interface Configurable Target:
| Property | Description |
Users > Add ( |
user_name | Populate the Add User properties with a user name and password, then confirm the password, and assign a user role. The user name must be 4 to 16 characters and must start with an alphabetic character and use no spaces. The password must be 8 to 16 characters, which are case sensitive. Use any characters except a colon and space. CLI Create User Syntax: create / SP|/users/ user_name_for_account password= password_for_account role= administrator|operator|a|u|c|r|o|s Example Syntax: create /SP/users user5 password=administrator role=aucr Note. When adding a user account through the CLI, it is unnecessary to provide a property value for a role or password. The role will default to Read-Only (o), and the CLI will prompt you to provide and confirm a password. |
Save |
Web interface – To apply changes made to properties within the Add User dialog, you must click Save. |
Table 3-9 View, Modify, or Remove User Account
Users ( |
View local user accounts configured in Oracle ILOM. CLI View Users Syntax: show /SP/users Example syntax:
Users > Edit ( |
Password=user_configurable|role=administrator |operator|advanced (a|u|c|r|o|s) Edit the applicable User properties for password and user role.
characters except a colon and space. Note that the user roles cannot be
modified for the preconfigured Web interface – Click Save to apply the changes made within the Edit User dialog. CLI Edit User Account Syntax: set /SP/users user_name password=assign_new_password role= administrator|operator|a|u|c|r|o|s Example Syntax: set /SP/users user5 password=administrator role=auco |
Users > Delete ( |
Specify the name of the user account to delete. When prompted, confirm the action. Note: Deleting a user account will not automatically terminate any active user sessions remaining in Oracle ILOM for that user. To manage user sessions, see Manage User Authenticated Sessions per Managed Device.CLI Delete User Account Syntax: delete /SP/users/user_name Example Syntax: delete /SP/users/user5 |
