CSE_PARTS_LIST_COMPONENTS_INT
This table stores the main transactional actions that happens to change the state of the asset or the asset structure business objects.
Details
Schema: FUSION
Object owner: CSE
Object type: TABLE
Tablespace: INTERFACE
Primary Key
Name | Columns |
CSE_PARTS_LIST_COMPS_INT_PK |
INTERFACE_ROW_ID |
Columns
Name | Datatype | Length | Precision | Not-null | Comments |
INTERFACE_ROW_ID | NUMBER | 18 | Yes | Interface Row Identifier. The primary key column. | |
INTERFACE_STATUS_CODE | VARCHAR2 | 30 | The status of the interface row. The processor heavily relies on this column to persist interim status of the row upon processing data in bulk. | ||
INTERFACE_BATCH_ID | NUMBER | 18 | Interface Batch Identifier. This is the foreign key to the Interface Batch entity. | ||
INTERFACE_BATCH_CODE | VARCHAR2 | 30 | The interface batch code. The user key to the interface batch entity. | ||
INTERFACE_RECORD_NUMBER | VARCHAR2 | 18 | Interface Record Number. This is the user key to link the child interface entities together. | ||
ACTION_CODE | VARCHAR2 | 30 | The various actions that can be performed on the parts list components using the import functionality. | ||
LIST_COMPONENT_ID | NUMBER | 18 | Unique Parts List Component Identifier. The primary key column. | ||
ASSET_NUMBER | VARCHAR2 | 80 | Asset Number. The user key to the asset business object. | ||
ASSET_ID | NUMBER | Asset Identifier. Foreign key to the Assets table. | |||
ITEM_ORGANIZATION_ID | NUMBER | 18 | Item Organization Identifier. Foreign key to the maintenance organization. | ||
ITEM_ORGANIZATION_CODE | VARCHAR2 | 18 | The item organization user key. The organization where the asset was last located. | ||
ITEM_ID | NUMBER | 18 | Inventory Item Identifier. Foreign key to the item master. | ||
ITEM_NUMBER | VARCHAR2 | 300 | Inventory Item Number. The user key to identify the product associated to the asset. | ||
ITEM_REVISION | VARCHAR2 | 18 | Inventory Item Revision. The revision of the item that is used as the component. | ||
COMPONENT_QUANTITY | NUMBER | Component Item Quantity. This many units of spare parts are needed. | |||
SECONDARY_QUANTITY | NUMBER | This is the secondary quantity captured when the item supports dual units of measure. | |||
SECONDARY_UOM_CODE | VARCHAR2 | 3 | The unit of measure code for the secondary quantity. This is captured only when the item supports dual units of measure. | ||
PARTITION_NUMBER | NUMBER | 18 | For parallel processing, the internal logic uses this column to stripe the bunch of assets in to a partition. | ||
ATTRIBUTE_CATEGORY | VARCHAR2 | 80 | Descriptive Flexfield: structure definition of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR1 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR2 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR3 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR4 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR5 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR6 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR7 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR8 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR9 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR10 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR11 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR12 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR13 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR14 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR15 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR16 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR17 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR18 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR19 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_CHAR20 | VARCHAR2 | 240 | Descriptive Flexfield: segment of the user descriptive flexfield. | ||
ATTRIBUTE_NUMBER1 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER2 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER3 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER4 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER5 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER6 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER7 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER8 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER9 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_NUMBER10 | NUMBER | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_DATE1 | DATE | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_DATE2 | DATE | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_DATE3 | DATE | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_DATE4 | DATE | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_DATE5 | DATE | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_TIMESTAMP1 | TIMESTAMP | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_TIMESTAMP2 | TIMESTAMP | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_TIMESTAMP3 | TIMESTAMP | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_TIMESTAMP4 | TIMESTAMP | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
ATTRIBUTE_TIMESTAMP5 | TIMESTAMP | Descriptive Flexfield: segment of the user descriptive flexfield. | |||
CREATED_BY | VARCHAR2 | 64 | Who column: indicates the user who created the row. | ||
CREATION_DATE | TIMESTAMP | Who column: indicates the date and time of the creation of the row. | |||
LAST_UPDATED_BY | VARCHAR2 | 64 | Who column: indicates the user who last updated the row. | ||
LAST_UPDATE_DATE | TIMESTAMP | Who column: indicates the date and time of the last update of the row. | |||
LAST_UPDATE_LOGIN | VARCHAR2 | 32 | Who column: indicates the session login associated to the user who last updated the row. | ||
REQUEST_ID | NUMBER | 18 | Enterprise Service Scheduler: indicates the request ID of the job that created or last updated the row. | ||
JOB_DEFINITION_NAME | VARCHAR2 | 100 | Enterprise Service Scheduler: indicates the name of the job that created or last updated the row. | ||
JOB_DEFINITION_PACKAGE | VARCHAR2 | 900 | Enterprise Service Scheduler: indicates the package name of the job that created or last updated the row. | ||
LOAD_REQUEST_ID | NUMBER | 18 | Load Request Identifier. This is to support the loading of the interface records from the data files using the cloud framework. |
Indexes
Index | Uniqueness | Tablespace | Columns |
CSE_PARTS_LIST_COMPS_INT_N01 | Non Unique | Default | INTERFACE_RECORD_NUMBER |
CSE_PARTS_LIST_COMPS_INT_N02 | Non Unique | Default | INTERFACE_BATCH_ID, INTERFACE_STATUS_CODE, ACTION_CODE |
CSE_PARTS_LIST_COMPS_INT_U01 | Unique | Default | INTERFACE_ROW_ID |
