This section contains full details about the parts of the IPQoS configuration file. The IPQoS boot-time activated policy is stored in the file /etc/inet/ipqosinit.conf. Although you can edit this file, the best practice for a new IPQoS system is to create a configuration file with a different name. Tasks for applying and debugging an IPQoS configuration are in Chapter 3, Creating the IPQoS Configuration File Tasks.
The syntax of the IPQoS configuration file is shown in Example 6–3.
Example 6-3 Syntax of the IPQoS Configuration Filefile_format_version ::= fmt_version version action_clause ::= action { name action-name module module-name params-clause | "" cf-clauses } action_name ::= string module_name ::= ipgpc | dlcosmk | dscpmk | tswtclmt | tokenmt | flowacct params_clause ::= params { parameters params-stats | "" } parameters ::= prm-name-value parameters | "" prm_name_value ::= param-name param-value params_stats ::= global-stats Boolean cf_clauses ::= class-clause cf-clauses | filter-clause cf-clauses | "" class_clause ::= class { name class-name next_action next-action-name class-stats | "" } class_name ::= string next_action_name ::= string class_stats ::= enable_stats Boolean boolean ::= TRUE | FALSE filter_clause ::= filter { name filter-name class class–name parameters } filter_name ::= string
