Managing Serial Networks Using UUCP and PPP in Oracle® Solaris 11.2
Exit Print View
Updated: July 2014
Creating PPPoE Tunnels for DSL Support
By using PPPoE, you can provide PPP over high-speed digital services to multiple clients that are using one or more DSL modems. PPPoE implements these services by creating an Ethernet tunnel through three participants: the enterprise, the telephone company, and the service provider.
This section contains detailed information about PPPoE commands and files, which is summarized in the next table.
Table 8-2  PPPoE Commands and Configuration Files
File or Command
Description
For Instructions
/etc/ppp/pppoe
A file that contains characteristics that are applied by default to all tunnels that were set up by PPPoE on the system
/etc/ppp/pppoe.device
A file that contains characteristics of a particular interface that is used by PPPoE for a tunnel
/etc/ppp/pppoe.if
File that lists the Ethernet interface over which runs the tunnel that is set up by PPPoE
/usr/sbin/sppptun
Command for configuring the Ethernet interfaces that are involved in a PPPoE tunnel
/usr/lib/inet/pppoed
Command and options for using PPPoE to set up a tunnel
