Developer's Guide to Oracle® Solaris 11 Security
Exit Print View
Updated: July 2014
GSS-API Reference
Additional GSS-API definitions can be found in the file gssapi.h.
GSS-API Functions
The Oracle Solaris software implements the GSS-API functions. For more information on each function, see its man page. See also Functions From Previous Versions of GSS-API.
gss_acquire_cred()
Assume a global identity by obtaining a GSS-API credential handle for preexisting credentials
gss_add_cred()
Construct credentials incrementally
gss_inquire_cred()
Obtain information about a credential
gss_inquire_cred_by_mech()
Obtain per-mechanism information about a credential
gss_release_cred()
Discard a credential handle
gss_init_sec_context()
Initiate a security context with a peer application
gss_accept_sec_context()
Accept a security context initiated by a peer application
gss_delete_sec_context()
Discard a security context
gss_process_context_token()
Process a token on a security context from a peer application
gss_context_time()
Determine how long a context is to remain valid
gss_inquire_context()
Obtain information about a security context
gss_wrap_size_limit()
Determine token-size limit for gss_wrap() on a context
gss_export_sec_context()
Transfer a security context to another process
gss_import_sec_context()
Import a transferred context
gss_get_mic()
Calculate a cryptographic message integrity code (MIC) for a message
gss_verify_mic()
Check a MIC against a message to verify integrity of a received message
gss_wrap()
Attach a MIC to a message, and optionally encrypt the message content
gss_unwrap()
Verify a message with attached MIC. Decrypt message content if necessary
gss_import_name()
Convert a contiguous string name to an internal-form name
gss_display_name()
Convert internal-form name to text
gss_compare_name()
Compare two internal-form names
gss_release_name()
Discard an internal-form name
gss_inquire_names_for_mech()
List the name types supported by the specified mechanism
gss_inquire_mechs_for_name()
List mechanisms that support the specified name type
gss_canonicalize_name()
Convert an internal name to a mechanism name (MN)
gss_export_name()
Convert an MN to export form
gss_duplicate_name()
Create a copy of an internal name
gss_add_oid_set_member()
Add an object identifier to a set
gss_display_status()
Convert a GSS-API status code to text
gss_indicate_mechs()
Determine available underlying authentication mechanisms
gss_release_buffer()
Discard a buffer
gss_release_oid_set()
Discard a set of object identifiers
gss_create_empty_oid_set()
Create a set with no object identifiers
gss_test_oid_set_member()
Determine whether an object identifier is a member of a set
This section explains functions that were included in previous versions of the GSS-API.
Functions for Manipulating OIDs
    The Oracle Solaris implementation of GSS-API provides the following functions for convenience and for backward compatibility. However, these functions might not be supported by other implementations of GSS-API.
  • gss_delete_oid()
  • gss_oid_to_str()
  • gss_str_to_oid()
Although a mechanism's name can be converted from a string to an OID, programmers should use the default GSS-API mechanism if at all possible.
Renamed Functions
    The following functions have been supplanted by newer functions. In each case, the new function is the functional equivalent of the older function. Although the old functions are supported, developers should replace these functions with the newer functions whenever possible.
  • gss_sign() has been replaced with gss_get_mic().
  • gss_verify() has been replaced with gss_verify_mic().
  • gss_seal() has been replaced with gss_wrap().
  • gss_unseal() has been replaced with gss_unwrap().
GSS-API Status Codes
Major status codes are encoded in the OM_uint32 as shown in the following figure.
Figure C-1  Major-Status Encoding
image:Diagram shows how major status codes are encoded in OM_uint32.
If a GSS-API routine returns a GSS status code whose upper 16 bits contain a nonzero value, the call has failed. If the calling error field is nonzero, the application's call of the routine was erroneous. The calling errors are listed in Table C–1. If the routine error field is nonzero, the routine failed because of a routine-specific error, as listed in Table C–2. The bits in the supplementary information field of the status code can be set whether the upper 16 bits indicate a failure or a success. The meaning of individual bits is listed in Table C–3.
GSS-API Major Status Code Values
The following tables list the calling errors that are returned by GSS-API. These errors are specific to a particular language-binding, which is C in this case.
Table C-1  GSS-API Calling Errors
Error
Value in Field
Meaning
GSS_S_CALL_INACCESSIBLE_READ
1
An input parameter that is required could not be read
GSS_S_CALL_INACCESSIBLE_WRITE
2
A required output parameter could not be written
GSS_S_CALL_BAD_STRUCTURE
3
A parameter was malformed
The following table lists the GSS-API routine errors, generic errors that are returned by GSS-API functions.
Table C-2  GSS-API Routine Errors
Error
Value in Field
Meaning
GSS_S_BAD_MECH
1
An unsupported mechanism was requested.
GSS_S_BAD_NAME
2
An invalid name was supplied.
GSS_S_BAD_NAMETYPE
3
A supplied name was of an unsupported type.
GSS_S_BAD_BINDINGS
4
Incorrect channel bindings were supplied.
GSS_S_BAD_STATUS
5
An invalid status code was supplied.
GSS_S_BAD_MIC, GSS_S_BAD_SIG
6
A token had an invalid MIC.
GSS_S_NO_CRED
7
The credentials were unavailable, inaccessible, or not supplied.
GSS_S_NO_CONTEXT
8
No context has been established.
GSS_S_DEFECTIVE_TOKEN
9
A token was invalid.
GSS_S_DEFECTIVE_CREDENTIAL
10
A credential was invalid.
GSS_S_CREDENTIALS_EXPIRED
11
The referenced credentials have expired.
GSS_S_CONTEXT_EXPIRED
12
The context has expired.
GSS_S_FAILURE
13
Miscellaneous failure. The underlying mechanism detected an error for which no specific GSS–API status code is defined. The mechanism-specific status code, that is, the minor-status code, provides more details about the error.
GSS_S_BAD_QOP
14
The quality-of-protection that was requested could not be provided.
GSS_S_UNAUTHORIZED
15
The operation is forbidden by local security policy.
GSS_S_UNAVAILABLE
16
The operation or option is unavailable.
GSS_S_DUPLICATE_ELEMENT
17
The requested credential element already exists.
GSS_S_NAME_NOT_MN
18
The provided name was not a mechanism name (MN).
The name GSS_S_COMPLETE, which is a zero value, indicates an absence of any API errors or supplementary information bits.
The following table lists the supplementary information values returned by GSS-API functions.
Table C-3  GSS-API Supplementary Information Codes
Code
Bit Number
Meaning
GSS_S_CONTINUE_NEEDED
0 (LSB)
Returned only by gss_init_sec_context() or gss_accept_sec_context(). The routine must be called again to complete its function.
GSS_S_DUPLICATE_TOKEN
1
The token was a duplicate of an earlier token.
GSS_S_OLD_TOKEN
2
The token's validity period has expired.
GSS_S_UNSEQ_TOKEN
3
A later token has already been processed.
GSS_S_GAP_TOKEN
4
An expected per-message token was not received.
For more on status codes, see GSS-API Status Codes.
Displaying Status Codes
The function gss_display_status() translates GSS-API status codes into text format. This format allows the codes to be displayed to a user or put in a text log. gss_display_status() only displays one status code at a time, and some functions can return multiple status conditions. Accordingly, gss_display_status() should be called as part of a loop. When gss_display_status() indicates a non-zero status code, another status code is available for the function to fetch.
Example C-1  Displaying Status Codes with gss_display_status()
OM_uint32 message_context;
OM_uint32 status_code;
OM_uint32 maj_status;
OM_uint32 min_status;
gss_buffer_desc status_string;
message_context = 0;
do {
     maj_status = gss_display_status(
               &min_status,
               status_code,
               GSS_C_GSS_CODE,
               GSS_C_NO_OID,
               &message_context,
               &status_string);
     fprintf(stderr, "%.*s\n", \
               (int)status_string.length, \
               (char *)status_string.value);
     gss_release_buffer(&min_status, &status_string,);
} while (message_context != 0);
Status Code Macros
The macros, GSS_CALLING_ERROR(), GSS_ROUTINE_ERROR() and GSS_SUPPLEMENTARY_INFO(), take a GSS status code. These macros remove all information except for the relevant field. For example, the GSS_ROUTINE_ERROR() can be applied to a status code to remove the calling errors and supplementary information fields. This operation leaves the routine errors field only. The values delivered by these macros can be directly compared with a GSS_S_xxx symbol of the appropriate type. The macro GSS_ERROR() returns a non-zero value if a status code indicates a calling or routine error, and a zero value otherwise. All macros that are defined by GSS-API evaluate the arguments exactly once.
GSS-API Data Types and Values
    This section describes various types of GSS-API data types and values. Some data types, such as gss_cred_id_t or gss_name_t, are opaque to the user. These data types do not need to be discussed. This section explains the following topics:
  • Basic GSS-API Data Types – Shows the definitions of the OM_uint32, gss_buffer_desc, gss_OID_desc, gss_OID_set_desc_struct, and gss_channel_bindings_struct data types.
  • Name Types – Shows the various name formats recognized by the GSS-API for specifying names.
  • Address Types for Channel Bindings – Shows the various values that can be used as the initiator_addrtype and acceptor_addrtype fields of the gss_channel_bindings_t structure.
This section describes data types that are used by GSS-API.
OM_uint32
The OM_uint32 is a platform-independent 32–bit unsigned integer.
gss_buffer_desc
The definition of the gss_buffer_desc with the gss_buffer_t pointer takes the following form:
typedef struct gss_buffer_desc_struct {
        size_t length;
        void *value;
} gss_buffer_desc, *gss_buffer_t;
gss_OID_desc
The definition of the gss_OID_desc with the gss_OID pointer takes the following form:
typedef struct gss_OID_desc_struct {
        OM_uint32 length;
        void*elements;
} gss_OID_desc, *gss_OID;
gss_OID_set_desc
The definition of the gss_OID_set_desc with the gss_OID_set pointer takes the following form:
typedef struct gss_OID_set_desc_struct  {
        size_t  count;
        gss_OID elements;
} gss_OID_set_desc, *gss_OID_set;
The definition of the gss_channel_bindings_struct structure and the gss_channel_bindings_t pointer has the following form:
typedef struct gss_channel_bindings_struct {
        OM_uint32 initiator_addrtype;
        gss_buffer_desc initiator_address;
        OM_uint32 acceptor_addrtype;
        gss_buffer_desc acceptor_address;
        gss_buffer_desc application_data;
} *gss_channel_bindings_t;
Name Types
A name type indicates the format of the associated name. See Names in GSS-API and GSS-API OIDs for more on names and name types. The GSS-API supports the gss_OID name types in the following table.
GSS_C_NO_NAME
The symbolic name GSS_C_NO_NAME is recommended as a parameter value to indicate that no value is supplied in the transfer of names.
GSS_C_NO_OID
This value corresponds to a null input value instead of an actual object identifier. Where specified, the value indicates interpretation of an associated name that is based on a mechanism-specific default printable syntax.
GSS_C_NT_ANONYMOUS
A means to identify anonymous names. This value can be compared with to determine in a mechanism-independent fashion whether a name refers to an anonymous principal.
GSS_C_NT_EXPORT_NAME
A name that has been exported with the gss_export_name() function.
GSS_C_NT_HOSTBASED_SERVICE
Used to represent services that are associated with host computers. This name form is constructed using two elements, service and hostname, as follows: service@hostname.
GSS_C_NT_MACHINE_UID_NAME
Used to indicate a numeric user identifier corresponding to a user on a local system. The interpretation of this value is OS-specific. The gss_import_name() function resolves this UID into a user name, which is then treated as the User Name Form.
GSS_C_NT_STRING_STRING_UID_NAME
Used to indicate a string of digits that represents the numeric user identifier of a user on a local system. The interpretation of this value is OS-specific. This name type is similar to the Machine UID Form, except that the buffer contains a string that represents the user ID.
GSS_C_NT_USER_NAME
A named user on a local system. The interpretation of this value is OS-specific. The value takes the form: username.
The following table shows the possible values for the initiator_addrtype and acceptor_addrtype fields of the gss_channel_bindings_struct structure. These fields indicate the format that a name can take, for example, ARPAnet IMP address or AppleTalk address. Channel bindings are discussed in Using Channel Bindings in GSS-API.
Table C-4  Channel Binding Address Types
Field
Value (Decimal)
Address Type
GSS_C_AF_UNSPEC
0
Unspecified address type
GSS_C_AF_LOCAL
1
Host-local
GSS_C_AF_INET
2
Internet address type, for example, IP
GSS_C_AF_IMPLINK
3
ARPAnet IMP
GSS_C_AF_PUP
4
pup protocols, for example, BSP
GSS_C_AF_CHAOS
5
MIT CHAOS protocol
GSS_C_AF_NS
6
XEROX NS
GSS_C_AF_NBS
7
nbs
GSS_C_AF_ECMA
8
ECMA
GSS_C_AF_DATAKIT
9
Datakit protocols
GSS_C_AF_CCITT
10
CCITT
GSS_C_AF_SNA
11
IBM SNA
GSS_C_AF_DECnet
12
DECnet
GSS_C_AF_DLI
13
Direct data link interface
GSS_C_AF_LAT
14
LAT
GSS_C_AF_HYLINK
15
NSC Hyperchannel
GSS_C_AF_APPLETALK
16
AppleTalk
GSS_C_AF_BSC
17
BISYNC
GSS_C_AF_DSS
18
Distributed system services
GSS_C_AF_OSI
19
OSI TP4
GSS_C_AF_X25
21
X.25
GSS_C_AF_NULLADDR
255
No address specified
Implementation-Specific Features in GSS-API
Some aspects of the GSS-API can differ between implementations of the API. In most cases, differences in implementations have only minimal effect on programs. In all cases, developers can maximize portability by not relying on any behavior that is specific to a given implementation, including the Oracle Solaris implementation.
Oracle Solaris-Specific Functions
The Oracle Solaris implementation does not have customized GSS-API functions.
Human-Readable Name Syntax
Implementations of GSS-API can differ in the printable syntax that corresponds to names. For portability, applications should not compare names that use human-readable, that is, printable, forms. Instead, such applications should use gss_compare_name() to determine whether an internal-format name matches any other name.
The Oracle Solaris implementation of gss_display_name() displays names as follows. If the input_nameargument denotes a user principal, the gss_display_name() returns user_principal@realm as the output_name_buffer and the gss_OID value as the output_name_type. If Kerberos v5 is the underlying mechanism, gss_OID is 1.2.840.11354.1.2.2.
If gss_display_name() receives a name that was created by gss_import_name() with the GSS_C_NO_OID name type, gss_display_name() returns GSS_C_NO_OID in the output_name_type parameter.
Format of Anonymous Names
The gss_display_name() function outputs the string '<anonymous>' to indicate an anonymous GSS-API principal. The name type OID associated with this name is GSS_C_NT_ANONYMOUS. No other valid printable names supported by the Oracle Solaris implementation should be surrounded by angle brackets (<>).
Implementations of Selected Data Types
The following data types have been implemented as pointers, although some implementations might specify these types as arithmetic types: gss_cred_t, gss_ctx_id_t, and gss_name_t.
Deletion of Contexts and Stored Data
When context establishment fails, the Oracle Solaris implementation does not automatically delete partially built contexts. Applications should therefore handle this event by deleting the contexts with gss_delete_sec_context().
The Oracle Solaris implementation automatically releases stored data, such as internal names, through memory management. However, applications should still call appropriate functions, such as gss_release_name(), when data elements are no longer needed.
Protection of Channel-Binding Information
Support for channel bindings varies by mechanism. Both the Diffie-Hellman mechanism and the Kerberos v5 mechanism support channel bindings.
Developers should assume that channel bindings data do not have confidentiality protection. Although the Kerberos v5 mechanism provides this protection, confidentiality for channel-bindings data is not available with the Diffie-Hellman mechanism.
Context Exportation and Interprocess Tokens
The Oracle Solaris implementation detects and rejects attempted multiple imports of the same context.
Types of Credentials Supported
The Oracle Solaris implementation of the GSS-API supports the acquisition of GSS_C_INITIATE, GSS_C_ACCEPT, and GSS_C_BOTH credentials through gss_acquire_cred().
Credential Expiration
The Oracle Solaris implementation of the GSS-API supports credential expiration. Therefore, programmers can use parameters that relate to credential lifetime in functions such as gss_acquire_cred() and gss_add_cred().
Context Expiration
The Oracle Solaris implementation of the GSS-API supports context expiration. Therefore, programmers can use parameters that relate to context lifetime in functions such as gss_init_sec_context() and gss_inquire_context().
Wrap Size Limits and QOP Values
The Oracle Solaris implementation of the GSS-API, as opposed to any underlying mechanism, does not impose a maximum size for messages to be processed by gss_wrap(). Applications can determine the maximum message size with gss_wrap_size_limit().
The Oracle Solaris implementation of the GSS-API detects invalid QOP values when gss_wrap_size_limit() is called.
Use of minor_status Parameter
In the Oracle Solaris implementation of the GSS-API, functions return only mechanism-specific information in the minor_status parameter. Other implementations might include implementation-specific return values as part of the returned minor-status code.
Kerberos v5 Status Codes
Each GSS-API function returns two status codes: a major status code and a minor status code. Major status codes relate to the behavior of GSS-API. For example, if an application attempts to transmit a message after a security context has expired, GSS-API returns a major status code of GSS_S_CONTEXT_EXPIRED. Major status codes are listed in GSS-API Status Codes.
Minor status codes are returned by the underlying security mechanisms supported by a given implementation of GSS-API. Every GSS-API function takes as the first argument a minor_status or minor_stat parameter. An application can examine this parameter when the function returns, successfully or not, to see the status that is returned by the underlying mechanism.
The following tables list the status messages that can be returned by Kerberos v5 in the minor_status argument. For more on GSS-API status codes, see GSS-API Status Codes.
Messages Returned in Kerberos v5 for Status Code 1
The following table lists the minor status messages that are returned in Kerberos v5 for status code 1.
Table C-5  Kerberos v5 Status Codes 1
Minor Status
Value
Meaning
KRB5KDC_ERR_NONE
-1765328384L
No error
KRB5KDC_ERR_NAME_EXP
-1765328383L
Client's entry in database has expired
KRB5KDC_ERR_SERVICE_EXP
-1765328382L
Server's entry in database has expired
KRB5KDC_ERR_BAD_PVNO
-1765328381L
Requested protocol version not supported
KRB5KDC_ERR_C_OLD_MAST_KVNO
-1765328380L
Client's key is encrypted in an old master key
KRB5KDC_ERR_S_OLD_MAST_KVNO
-1765328379L
Server's key is encrypted in an old master key
KRB5KDC_ERR_C_PRINCIPAL_UNKNOWN
-1765328378L
Client not found in Kerberos database
KRB5KDC_ERR_S_PRINCIPAL_UNKNOWN
-1765328377L
Server not found in Kerberos database
KRB5KDC_ERR_PRINCIPAL_NOT_UNIQUE
-1765328376L
Principal has multiple entries in Kerberos database
KRB5KDC_ERR_NULL_KEY
-1765328375L
Client or server has a null key
KRB5KDC_ERR_CANNOT_POSTDATE
-1765328374L
Ticket is ineligible for postdating
KRB5KDC_ERR_NEVER_VALID
-1765328373L
Requested effective lifetime is negative or too short
KRB5KDC_ERR_POLICY
-1765328372L
KDC policy rejects request
KRB5KDC_ERR_BADOPTION
-1765328371L
KDC can't fulfill requested option
KRB5KDC_ERR_ETYPE_NOSUPP
-1765328370L
KDC has no support for encryption type
KRB5KDC_ERR_SUMTYPE_NOSUPP
-1765328369L
KDC has no support for checksum type
KRB5KDC_ERR_PADATA_TYPE_NOSUPP
-1765328368L
KDC has no support for padata type
KRB5KDC_ERR_TRTYPE_NOSUPP
-1765328367L
KDC has no support for transited type
KRB5KDC_ERR_CLIENT_REVOKED
-1765328366L
Client's credentials have been revoked
KRB5KDC_ERR_SERVICE_REVOKED
-1765328365L
Credentials for server have been revoked
Messages Returned in Kerberos v5 for Status Code 2
The following table lists the minor status messages that are returned in Kerberos v5 for status code 2.
Table C-6  Kerberos v5 Status Codes 2
Minor Status
Value
Meaning
KRB5KDC_ERR_TGT_REVOKED
-1765328364L
TGT has been revoked
KRB5KDC_ERR_CLIENT_NOTYET
-1765328363L
Client not yet valid, try again later
KRB5KDC_ERR_SERVICE_NOTYET
-1765328362L
Server not yet valid, try again later
KRB5KDC_ERR_KEY_EXP
-1765328361L
Password has expired
KRB5KDC_ERR_PREAUTH_FAILED
-1765328360L
Preauthentication failed
KRB5KDC_ERR_PREAUTH_REQUIRED
-1765328359L
Additional preauthentication required
KRB5KDC_ERR_SERVER_NOMATCH
-1765328358L
Requested server and ticket don't match
KRB5PLACEHOLD_27 through KRB5PLACEHOLD_30
-1765328357L through -1765328354L
KRB5 error codes 27 through 30 (reserved)
KRB5KRB_AP_ERR_BAD_INTEGRITY
-1765328353L
Decrypt integrity check failed
KRB5KRB_AP_ERR_TKT_EXPIRED
-1765328352L
Ticket expired
KRB5KRB_AP_ERR_TKT_NYV
-1765328351L
Ticket not yet valid
KRB5KRB_AP_ERR_REPEAT
-1765328350L
Request is a replay
KRB5KRB_AP_ERR_NOT_US
-1765328349L
The ticket isn't for us
KRB5KRB_AP_ERR_BADMATCH
-1765328348L
Ticket/authenticator do not match
KRB5KRB_AP_ERR_SKEW
-1765328347L
Clock skew too great
KRB5KRB_AP_ERR_BADADDR
-1765328346L
Incorrect net address
KRB5KRB_AP_ERR_BADVERSION
-1765328345L
Protocol version mismatch
KRB5KRB_AP_ERR_MSG_TYPE
-1765328344L
Invalid message type
KRB5KRB_AP_ERR_MODIFIED
-1765328343L
Message stream modified
KRB5KRB_AP_ERR_BADORDER
-1765328342L
Message out of order
KRB5KRB_AP_ERR_ILL_CR_TKT
-1765328341L
Illegal cross-realm ticket
KRB5KRB_AP_ERR_BADKEYVER
-1765328340L
Key version is not available
Messages Returned in Kerberos v5 for Status Code 3
The following table lists the minor status messages that are returned in Kerberos v5 for status code 3.
Table C-7  Kerberos v5 Status Codes 3
Minor Status
Value
Meaning
KRB5KRB_AP_ERR_NOKEY
-1765328339L
Service key not available
KRB5KRB_AP_ERR_MUT_FAIL
-1765328338L
Mutual authentication failed
KRB5KRB_AP_ERR_BADDIRECTION
-1765328337L
Incorrect message direction
KRB5KRB_AP_ERR_METHOD
-1765328336L
Alternative authentication method required
KRB5KRB_AP_ERR_BADSEQ
-1765328335L
Incorrect sequence number in message
KRB5KRB_AP_ERR_INAPP_CKSUM
-1765328334L
Inappropriate type of checksum in message
KRB5PLACEHOLD_51 throughKRB5PLACEHOLD_59
-1765328333L through -1765328325L
KRB5 error codes 51 through 59 (reserved)
KRB5KRB_ERR_GENERIC
-1765328324L
Generic error
KRB5KRB_ERR_FIELD_TOOLONG
-1765328323L
Field is too long for this implementation
KRB5PLACEHOLD_62 through KRB5PLACEHOLD_127
-1765328322L through -1765328257L
KRB5 error codes 62 through 127 (reserved)
value not returned
-1765328256L
For internal use only
KRB5_LIBOS_BADLOCKFLAG
-1765328255L
Invalid flag for file lock mode
KRB5_LIBOS_CANTREADPWD
-1765328254L
Cannot read password
KRB5_LIBOS_BADPWDMATCH
-1765328253L
Password mismatch
KRB5_LIBOS_PWDINTR
-1765328252L
Password read interrupted
KRB5_PARSE_ILLCHAR
-1765328251L
Illegal character in component name
KRB5_PARSE_MALFORMED
-1765328250L
Malformed representation of principal
KRB5_CONFIG_CANTOPEN
-1765328249L
Can't open/find Kerberos /etc/krb5/krb5 configuration file
KRB5_CONFIG_BADFORMAT
-1765328248L
Improper format of Kerberos /etc/krb5/krb5 configuration file
KRB5_CONFIG_NOTENUFSPACE
-1765328247L
Insufficient space to return complete information
KRB5_BADMSGTYPE
-1765328246L
Invalid message type has been specified for encoding
KRB5_CC_BADNAME
-1765328245L
Credential cache name malformed
Messages Returned in Kerberos v5 for Status Code 4
The following table lists the minor status messages that are returned in Kerberos v5 for status code 4.
Table C-8  Kerberos v5 Status Codes 4
Minor Status
Value
Meaning
KRB5_CC_UNKNOWN_TYPE
-1765328244L
Unknown credential cache type
KRB5_CC_NOTFOUND
-1765328243L
No matching credential has been found
KRB5_CC_END
-1765328242L
End of credential cache reached
KRB5_NO_TKT_SUPPLIED
-1765328241L
Request did not supply a ticket
KRB5KRB_AP_WRONG_PRINC
-1765328240L
Wrong principal in request
KRB5KRB_AP_ERR_TKT_INVALID
-1765328239L
Ticket has invalid flag set
KRB5_PRINC_NOMATCH
-1765328238L
Requested principal and ticket don't match
KRB5_KDCREP_MODIFIED
-1765328237L
KDC reply did not match expectations
KRB5_KDCREP_SKEW
-1765328236L
Clock skew too great in KDC reply
KRB5_IN_TKT_REALM_MISMATCH
-1765328235L
Client/server realm mismatch in initial ticket request
KRB5_PROG_ETYPE_NOSUPP
-1765328234L
Program lacks support for encryption type
KRB5_PROG_KEYTYPE_NOSUPP
-1765328233L
Program lacks support for key type
KRB5_WRONG_ETYPE
-1765328232L
Requested encryption type not used in message
KRB5_PROG_SUMTYPE_NOSUPP
-1765328231L
Program lacks support for checksum type
KRB5_REALM_UNKNOWN
-1765328230L
Cannot find KDC for requested realm
KRB5_SERVICE_UNKNOWN
-1765328229L
Kerberos service unknown
KRB5_KDC_UNREACH
-1765328228L
Cannot contact any KDC for requested realm
KRB5_NO_LOCALNAME
-1765328227L
No local name found for principal name
KRB5_MUTUAL_FAILED
-1765328226L
KRB5_RC_TYPE_EXISTS
-1765328225L
Replay cache type is already registered
KRB5_RC_MALLOC
-1765328224L
No more memory to allocate in replay cache code
KRB5_RC_TYPE_NOTFOUND
-1765328223L
Replay cache type is unknown
Messages Returned in Kerberos v5 for Status Code 5
The following table lists the minor status messages that are returned in Kerberos v5 for status code 5
Table C-9  Kerberos v5 Status Codes 5
Minor Status
Value
Meaning
KRB5_RC_UNKNOWN
-1765328222L
Generic unknown RC error
KRB5_RC_REPLAY
-1765328221L
Message is a replay
KRB5_RC_IO
-1765328220L
Replay I/O operation failed
KRB5_RC_NOIO
-1765328219L
Replay cache type does not support non-volatile storage
KRB5_RC_PARSE
-1765328218L
Replay cache name parse and format error
KRB5_RC_IO_EOF
-1765328217L
End-of-file on replay cache I/O
KRB5_RC_IO_MALLOC
-1765328216L
No more memory to allocate in replay cache I/O code
KRB5_RC_IO_PERM
-1765328215L
Permission denied in replay cache code
KRB5_RC_IO_IO
-1765328214L
I/O error in replay cache i/o code
KRB5_RC_IO_UNKNOWN
-1765328213L
Generic unknown RC/IO error
KRB5_RC_IO_SPACE
-1765328212L
Insufficient system space to store replay information
KRB5_TRANS_CANTOPEN
-1765328211L
Can't open/find realm translation file
KRB5_TRANS_BADFORMAT
-1765328210L
Improper format of realm translation file
KRB5_LNAME_CANTOPEN
-1765328209L
Can't open or find lname translation database
KRB5_LNAME_NOTRANS
-1765328208L
No translation is available for requested principal
KRB5_LNAME_BADFORMAT
-1765328207L
Improper format of translation database entry
KRB5_CRYPTO_INTERNAL
-1765328206L
Cryptosystem internal error
KRB5_KT_BADNAME
-1765328205L
Key table name malformed
KRB5_KT_UNKNOWN_TYPE
-1765328204L
Unknown Key table type
KRB5_KT_NOTFOUND
-1765328203L
Key table entry not found
KRB5_KT_END
-1765328202L
End of key table reached
KRB5_KT_NOWRITE
-1765328201L
Cannot write to specified key table
Messages Returned in Kerberos v5 for Status Code 6
The following table lists the minor status messages that are returned in Kerberos v5 for status code 6.
Table C-10  Kerberos v5 Status Codes 6
Minor Status
Value
Meaning
KRB5_KT_IOERR
-1765328200L
Error writing to key table
KRB5_NO_TKT_IN_RLM
-1765328199L
Cannot find ticket for requested realm
KRB5DES_BAD_KEYPAR
-1765328198L
DES key has bad parity
KRB5DES_WEAK_KEY
-1765328197L
DES key is a weak key
KRB5_BAD_ENCTYPE
-1765328196L
Bad encryption type
KRB5_BAD_KEYSIZE
-1765328195L
Key size is incompatible with encryption type
KRB5_BAD_MSIZE
-1765328194L
Message size is incompatible with encryption type
KRB5_CC_TYPE_EXISTS
-1765328193L
Credentials cache type is already registered
KRB5_KT_TYPE_EXISTS
-1765328192L
Key table type is already registered
KRB5_CC_IO
-1765328191L
Credentials cache I/O operation failed
KRB5_FCC_PERM
-1765328190L
Credentials cache file permissions incorrect
KRB5_FCC_NOFILE
-1765328189L
No credentials cache file found
KRB5_FCC_INTERNAL
-1765328188L
Internal file credentials cache error
KRB5_CC_WRITE
-1765328187L
Error writing to credentials cache file
KRB5_CC_NOMEM
-1765328186L
No more memory to allocate in credentials cache code
KRB5_CC_FORMAT
-1765328185L
Bad format in credentials cache
KRB5_INVALID_FLAGS
-1765328184L
Invalid KDC option combination, which is an internal library error
KRB5_NO_2ND_TKT
-1765328183L
Request missing second ticket
KRB5_NOCREDS_SUPPLIED
-1765328182L
No credentials supplied to library routine
KRB5_SENDAUTH_BADAUTHVERS
-1765328181L
Bad sendauth version was sent
KRB5_SENDAUTH_BADAPPLVERS
-1765328180L
Bad application version was sent by sendauth
KRB5_SENDAUTH_BADRESPONSE
-1765328179L
Bad response during sendauth exchange
KRB5_SENDAUTH_REJECTED
-1765328178L
Server rejected authentication during sendauth exchange
Messages Returned in Kerberos v5 for Status Code 7
The following table lists the minor status messages that are returned in Kerberos v5 for status code 7.
Table C-11  Kerberos v5 Status Codes 7
Minor Status
Value
Meaning
KRB5_PREAUTH_BAD_TYPE
-1765328177L
Unsupported preauthentication type
KRB5_PREAUTH_NO_KEY
-1765328176L
Required preauthentication key not supplied
KRB5_PREAUTH_FAILED
-1765328175L
Generic preauthentication failure
KRB5_RCACHE_BADVNO
-1765328174L
Unsupported format version number for replay cache
KRB5_CCACHE_BADVNO
-1765328173L
Unsupported credentials cache format version number
KRB5_KEYTAB_BADVNO
-1765328172L
Unsupported version number for key table format
KRB5_PROG_ATYPE_NOSUPP
-1765328171L
Program lacks support for address type
KRB5_RC_REQUIRED
-1765328170L
Message replay detection requires rcache parameter
KRB5_ERR_BAD_HOSTNAME
-1765328169L
Host name cannot be canonicalized
KRB5_ERR_HOST_REALM_UNKNOWN
-1765328168L
Cannot determine realm for host
KRB5_SNAME_UNSUPP_NAMETYPE
-1765328167L
Conversion to service principal is undefined for name type
KRB5KRB_AP_ERR_V4_REPLY
-1765328166L
Initial Ticket response appears to be Version 4 error
KRB5_REALM_CANT_RESOLVE
-1765328165L
Cannot resolve KDC for requested realm
KRB5_TKT_NOT_FORWARDABLE
-1765328164L
The requesting ticket cannot get forwardable tickets
KRB5_FWD_BAD_PRINCIPAL
-1765328163L
Bad principal name while trying to forward credentials
KRB5_GET_IN_TKT_LOOP
-1765328162L
Looping detected inside krb5_get_in_tkt
KRB5_CONFIG_NODEFREALM
-1765328161L
Configuration file /etc/krb5/krb5.conf does not specify default realm
KRB5_SAM_UNSUPPORTED
-1765328160L
Bad SAM flags in obtain_sam_padata
KRB5_KT_NAME_TOOLONG
-1765328159L
Keytab name too long
KRB5_KT_KVNONOTFOUND
-1765328158L
Key version number for principal in key table is incorrect
KRB5_CONF_NOT_CONFIGURED
-1765328157L
Kerberos /etc/krb5/krb5.conf configuration file not configured
ERROR_TABLE_BASE_krb5
-1765328384L
default
