man pages section 3: Extended Library Functions, Volume 3
Exit Print View
Updated: July 2014
ptree_create_prop(3PICLTREE)
Name
ptree_create_prop, ptree_destroy_prop - create or destroy a property
Synopsis
cc [ flag... ] file... –lpicltree [ library... ]
#include <picltree.h>
int ptree_create_prop(ptree_propinfo_t *pinfo, void *valbuf,
     picl_prophdl_t *proph);
int ptree_destroy_prop(picl_prophdl_t proph);
Description
The ptree_create_prop() function creates a property using the information specified in pinfo, which includes the name, type, access mode, and size of the property, as well as the read access function for a volatile property. The value of the property is specified in the buffer valbuf, which may be NULL for volatile properties. The handle of the property created is copied into the location given by proph. See libpicltree(3PICLTREE) for more information on the structure of ptree_propinfo_t structure.
The ptree_destroy_prop() function destroys the property specified by the handle proph. For a table property, the entire table is destroyed. The property to be destroyed must have been previously deleted.
Return Values
Upon successful completion, 0 is returned. On failure, a non-negative integer is returned to indicate an error.
PICL_STALEHANDLE is returned if the handle is no longer valid. This occurs if the PICL tree was refreshed or reinitialized.
PICL_INVALIDHANDLE is returned if the specified handle never existed.
Errors
PICL_NOTSUPPORTED
Property version not supported
PICL_VALUETOOBIG
Value exceeds maximum size
PICL_NOTPROP
Not a property
PICL_CANTDESTROY
Attempting to destroy before delete
PICL_RESERVEDNAME
Property name is reserved
PICL_INVREFERENCE
Invalid reference property value
PICL_INVALIDHANDLE
Invalid handle
PICL_STALEHANDLE
Stale handle
PICL_FAILURE
General system failure
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
libpicltree(3PICLTREE), ptree_add_prop(3PICLTREE), attributes(5)
