man pages section 9: DDI and DKI Driver Entry Points
Exit Print View
Updated: July 2014
audio_engine_start(9E)
Name
audio_engine_start, audio_engine_stop - start or stop an audio engine
Synopsis
#include <sys/audio/audio_driver.h>
int prefix_start(void *state);
void prefix_stop(void *state);
Parameters
state
pointer to driver supplied soft state
Interface Level
Solaris DDI specific (Solaris DDI)
Description
The audio_engine_start() function starts an audio engine that has been initialized with audio_engine_open(9E). This initiates actual playback or recording of audio. The data transfer must start at the first frame in the engine's buffer.
The audio_engine_stop() function stops an audio engine that was previously started with audio_engine_start() and resets the frame index back to 0. The master frame counter for the engine is not reset.
Once audio_engine_stop() returns, the engine must not perform any further data transfers to or from the audio buffer. Furthermore, actual play back or capture of audio associated with the engine shall have ceased.
Return Values
The audio_engine_start() function returns 0 on success or an error number on failure.
Context
These functions may be called from user, kernel, or interrupt context.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
See also
attributes(5), audio(7D) , audio_engine_open(9E), audio_engine_ops (9S)
