Load Plans that were originally generated in the ODI Repository for 11.1.1.10.1 do not exist in the ODI Repository for 11.1.1.10.2.
The steps to transfer content from the 11.1.1.10.1 repository to the 11.1.1.10.2 repository do not include transferring the original load plans. The load plans will not reflect any changes introduced as part of the upgrade, hence you need to generate a new load plan.
Configuration Manager retains the load plan definitions on upgrade even though any metadata associated with this load plan that was stored in ODI is no longer available. Use these existing definitions in Configuration Manager to regenerate load plans including Domains Only Load Plans. Note that any tasks that had previously executed pre-upgrade will execute in incremental mode post-upgrade while any new tasks that may be introduced in the generated load plan will initially execute in full mode.
To regenerate load plans:
