Use these instructions to upgrade the Oracle BI Applications binaries to release 11.1.1.10.2.
To upgrade Oracle BI Applications binaries:
- Shut down the WebLogic Administration Server, the BI and ODI Managed Servers, and the Node Manager. Shut down the BI processes using Oracle Process Manager and the Notification Server (OPMN).
- On the machine that hosts the Middleware Home and BI Oracle Home for the Oracle BI Applications 11.1.1.10.1 environment, run the Oracle BI Applications 11.1.1.10.2 installer. On Windows, run:
setup.exe –jreLoc <JDK or JRockit location>
, and on Linux or UNIX, run: ./runInstaller -jreLoc <JDK or JRockit location>
- Enter the full path of the inventory directory and the Operating System group name. Click Ok.
- The next dialog prompts you to run the scripts with root access. Click Ok
- Click Next in the Welcome dialog.
- Click Next in the Prerequisite Checks dialog.
- The Specify Installation Location dialog displays the MW_HOME and BI_ORACLE_HOME values for your existing Oracle BI Applications 11.1.1.10.1 environment. Verify the locations and click Next.
- When prompted to confirm whether you want to upgrade the existing BI_ORACLE_HOME, click Yes.
- In the Summary dialog, review the installation details and click Install to proceed.
- Click Next on the Installation Progress screen when the installation is complete.
- Click Finish on the Complete screen to complete the installation.
Do not start the WebLlogic servers and BI processes at this time.
