Use these instructions to apply FMW platform patches for Oracle BI Applications 11.1.1.10.2.
The Fusion Middleware platform patches are available for download as part of the Oracle Business Intelligence Applications 11.1.1.10.2 media pack. To use Oracle BI Applications 11.1.1.10.2, you must have Oracle BI Enterprise Edition (Oracle BI EE ) release 11.1.1.9.0 or later. Bundle Patches are included and will be applied to Oracle BI EE 11.1.1.9.0. If you have already applied higher Oracle BI EE Bundle Patch as compared to the Bundle patches supplied with media pack, then the Oracle BI EE patches will not be applied as part of this step. The release of ODI supported for Oracle BI Applications 11.1.1.10.2 is 11.1.1.9.0. An ODI patch is applied to 11.1.1.9.0 as part of this FMW patch application step.
To apply platform patches:Note:
Run the Perl script available in<BI_Oracle_Home>/biapps/tools/bin/APPLY_PATCHES.pl
to apply the patches. The Perl script requires a parameter input file apply_patches_import.txt
In this procedure, before you run the Perl script, update the parameter input file to reflect the appropriate directory paths.
