Applications Administration Guide > Audit Trail > About the Audit Trail Engine Business ServiceThe Audit Trail Engine business service is located in the Object Manager and stays active as long as the Object Manager is active. The purpose of the Audit Trail Engine business service is to capture changes (updates and deletes) to records and to store them in the designated format. For the various data operations, if the auditing condition is met, the business component being audited triggers the Audit Trail Engine business service. The methods listed in Table 12 are associated with the Audit Trail Engine business service. The Start, Stop, and ImportAll methods are accessible to an administrator and allow the performance of certain tasks. The easiest way to use these methods is through a workflow process. If you want to stop or restart the Audit Trail Engine, create a new workflow process, or reuse an existing one: create a business service node that implements the Stop method or the Start method. For general information about Siebel workflows, see Siebel Business Process Designer Administration Guide. |
Applications Administration Guide |
