Applications Administration Guide > Getting Started >
Entering License Keys
The Siebel license key is generated so that your organization's users can access the Siebel products that your organization has purchased. The license key is a series of numbers (up to 54 digits). Your organization's specific license key is included in the Welcome Package. You must enter this license key before you begin to use the Siebel product, products, or optional modules that your organization has purchased. Because the license key resides in the database and not on the client machine, everyone who accesses the Siebel database uses the same license key. Your license key activates the screens and views associated with the applications and modules that your organization has purchased. If you have been assigned multiple license keys, their effect is cumulative, as you enter them. Customers upgrading from earlier versions of Siebel software may notice differences between the Siebel product and the products listed in the Welcome Package. These generally reflects changes in naming and bundling of Siebel products. For example, a functionality that was previously sold separately might now be bundled into a single product, or included in a base application, or simply have been renamed. It is recommended that you run the application itself to verify that all of the functionality that you expected is there. Customers using Siebel products which are upgrades from earlier versions may notice differences between the views in the previous product and the views in the upgraded product. Reasons for this may include the following:
- The view you are looking for is not available from the application that you have launched.
- You logged in as a user who does not have responsibilities for the view. In order to evaluate all of the views available in the product, log in as a Siebel administrator.
- The method of accessing the functionality may have changed, or the functionality may have been replaced by more comprehensive features that work differently. Consult the Siebel Bookshelf for information on functionality changes in the latest release.
- The location or name of the screen or view may have changed. You can review the Site Map or consult the Siebel Bookshelf for information on current view locations.
However, if you do not see views that you expected, or if you see views that you did not expect, and feel that it impacts the functionality you have purchased, contact Siebel Technical Support as soon as possible. If your license key has expired, contact Siebel Technical Support. Entering the First License Key
Before you enter the first license key, the following software must be correctly installed: Gateway Name Server, Siebel Server, Siebel Database Server, Siebel Business Applications, and one of the following: Siebel Developer Web Client or Siebel Tools. After the first Siebel Developer Web Client or Siebel Tools installation, the first user to connect to the Siebel database is required to enter a license key in order to use the product. To enter the first license key
- Start either Siebel Developer Web Client or Siebel Tools.
NOTE: You have the choice of entering the first license key in either Siebel Developer Web Client or Siebel Tools. You can enter any Siebel license key in either Siebel Developer Web Client or Siebel Tools.
- Log in as the system administrator and connect to the server database.
Use SADMIN as the login name and SADMIN as the password, and choose Server in the Connect to drop-down list.
NOTE: If you are the first to log in to Siebel Developer Web Client after a new Siebel installation, you get the error message "There is no valid license key in the database." If you are the first to log in to Siebel Tools after a new Siebel installation, you get the error message "No valid license keys were found in the database."
- If you are logged in to Siebel Developer Web Client, click OK. If you are logged in to Siebel Tools, click Add Key.
- In the License Key dialog box, enter the Siebel Business base application license key or the Siebel Tools license key, and then click OK.
CAUTION: Enter only a Siebel Business base application license key or the Siebel Tools license key. If you enter an optional-module license key without having a Siebel Business base application license key already entered, an error message appears. The error occurs because the Home Page view is required to start Siebel Business base applications, and Home Page views are not included in optional module license keys.
- Close Siebel Developer Web Client or Siebel Tools, whichever you started in Step 1.
- Restart the Siebel Server System Service. (For more information, see Siebel System Administration Guide.)
- Start the Siebel application associated with the license key that you entered.
For example, if your license key is for Siebel Sales, start Siebel Sales; if your license key is for Siebel Tools, start Siebel Tools.
NOTE: After entering the initial license key, if you discover that you made an error when entering the license key, you can correct the license key in the Key Value field in the Application Administration screen, License Key view.
Entering an Additional License Key
After entering the initial key, you can add or delete license keys through Siebel Business Applications as long as your Siebel user responsibility includes the Siebel License Key view. You can do this immediately if your purchase included more than one license key, or you can add license keys as your organization purchases more Siebel applications or optional modules. To enter an additional license key using a Siebel application
- Start the Siebel application—for example, Siebel Call Center. You can use Siebel Web Client or Siebel Developer Web Client.
Use SADMIN as the login name and SADMIN as the password, and choose Server in the Connect to drop-down list. If the system administrator's password has been changed, use the current password.
- Navigate to the Administration - Application screen > License Keys view.
- Add the new license key:
- In the License Keys list, create a new record.
- In the new record, enter one license key in the Key Value field.
- Repeat Step a and Step b for each license key to be entered.
- Close the application.
Start any Siebel application or module associated with a license key you have entered. If you have any problems installing your license keys, contact Siebel Technical Support. To enter an additional license key using Siebel Tools
- Start Siebel Tools.
NOTE: To enter additional license keys in Siebel Tools, you must have first entered the Siebel Tools license key.
- Choose Help > Technical Support from the menu bar.
- In the Technical Support Information dialog box, click License Key.
- Add a license key:
- In the License Keys dialog box, click Add Key.
- In the new record, type in one license key and then click OK.
- Repeat Steps a and b for each license key to be entered.
- Close Siebel Tools.
Start any Siebel application or module associated with a license key you have entered. License Key Fields
Table 4 describes the files in the license key record.
Table 4. Fields in the License Key Record
Key Value |
The license key from your Welcome Package. Create a new record for each license key. |
Status |
Automatically entered based on the license key. OK means the license key has not expired. Expired means the license key has expired. |
MaxUsers |
Automatically entered based on the license key. The maximum number of concurrent users allowed in your license agreement with Siebel Systems. |
Expires |
Automatically entered based on the license key. The expiration date for the license key in your license agreement with Siebel Systems. |
Hiding Access to License Keys
There are two ways that you can hide access to license keys: hiding the License Keys administrative view within Siebel applications and hiding the License Key button within Siebel Tools.
- Within Siebel Applications. You may want to hide the License Keys view in the Application Administration screen, in order to discourage unauthorized users from attempting to change license keys. To hide the License Keys view, remove it from the responsibility associated with the users who should not have access to it. Responsibilities control the views to which users have access. For more information about creating and modifying responsibilities, see Security Guide for Siebel Business Applications.
- Within Siebel Tools. You may want to disable the License Key button, found in the Technical Support Information dialog box (available from the Siebel Tools Help menu), in order to discourage unauthorized users from attempting to change license keys. You can disable the License Key button by selecting the Siebel Administrator responsibility and deleting the Edit License Key view.
