Applications Administration Guide > Ongoing Application Administration Tasks >
Administering Global Time Zone Support
The time zones records that are shipped with Siebel applications as seed data include the 74 world time zones. These are the same time zones used by Microsoft in its operating systems. Use the Time Zone administration view to:
- Edit the text descriptions of time zones and their abbreviations
- Manage the active status of time zones to control which time zones are available to end users for use in the applications
- Manage multilingual translations to control how time zone information is displayed to users in multiple languages
Tasks for administering time zones include:
For more information on global time zone support, see Global Deployment Guide. Modifying Time Zones
You rarely need to modify a time zone's regional settings. However, you may want to modify other time zone settings such as the display name or daylight savings rules, as these occasionally change. NOTE: You cannot add or delete time zones.
To modify time zone settings
- Navigate to Administration - Data screen > Time Zone Administration view.
- In the Time Zone list, select the time zone record you want to modify.
- Modify the fields as necessary.
Some fields are described in the following table.
Name |
Name of time zone. |
Standard Abbreviation |
The abbreviation for the time zone. |
UTC Offset |
Offset, in minutes, from Coordinated Universal Time (UTC) when daylight savings is not in effect. |
DST Abbreviation |
The abbreviations for daylight savings time (DST). |
DST Bias |
Incremental DST offset, in minutes, from UTC when DST is not in effect. |
DST Start Ordinal |
Part of the rule that determines when DST starts. For example, if the rule is the first Sunday in April, First is defined in this field. |
DST Start Day |
Part of the rule that determines when DST starts. For example, if the rule is the first Sunday in April, Sunday is defined in this field. |
DST Start Month |
Part of the rule that determines when DST starts. For example, if the rule is the first Sunday in April, April is defined in this field. |
DST Start Time |
Minutes after midnight that DST starts. For example, if DST starts at 2:00 A.M., set the start time to 120. |
Maintaining Translations of Time Zones
You maintain translations of the text-based fields for each time zone using the Time Zone Administration view. To maintain translations of time zones
- In the Time Zone list, select the time zone you want to translate.
- In the Time Zone Translation list, create a new record and complete the necessary fields, including the translation of the Name field for the selected language.
- Repeat Step 3 for each language required for translation.
Date and Timestamps
The date and time used for timestamping records are obtained by the Siebel Server. When a remote user runs the Siebel client in disconnected mode, the Siebel Server runs on the user's machine and takes the date and time from that machine. If the Global Time Zone feature is enabled, then fields of data type UTCDATETIME are converted to UTC during Object Manager-based operations. For more information, see the Global Deployment Guide.
