Siebel Assignment Manager Administration Guide > Advanced Assignment Manager Configuration > Process of Configuring Assignment Manager to Copy Columns > Copying Columns Using the UIYou can set up Assignment Manager to copy columnar position or employee data using the UI or by submitting a server component job from the command-line interface. This topic explains how to copy columns using the UI. This task is one step in Process of Configuring Assignment Manager to Copy Columns. PrerequisitesThe following procedure assumes the Position Specific Columns and Employee Specific Columns properties are preconfigured for the assignment object and the Copy Candidate Specific Data (CopyCandSpecData) server component parameter is set to Yes. For information on how to configure these properties and parameter, see Configuring Assignment Object Properties and Modifying the Assignment Manager Server Component Parameters, respectively.
NOTE: Assignment Manager copies position- or employee-specific data only if the Use Key Value server component parameter value is set to either Rule Group or None. If None, position-specific data is copied from any position in the ACCNT_POSTN table that was updated last, given every position in the team is for the same business reason. TIP: When merging sales forces in production mode, Assignment Manager takes into account the list of key values, that is, Assignment Manager gets the latest updated position in all the rule groups in the Replace Key Values list with position-specific data. |
Siebel Assignment Manager Administration Guide |
