Siebel Assignment Manager Administration Guide > Assignment Rule Administration > Removing Assignment Criteria from Assignment RulesIn some cases, you may want to eliminate assignment criteria that appear in the Assignment Criteria view. To do so, you need to remove the unwanted criteria from the Assignment Criteria view as well as use Siebel Tools to disable the corresponding assignment attribute, assignment attribute column, assignment criteria, and assignment criteria attribute object definitions. Use the following procedure to remove unwanted criteria from the Assignment Criteria view. To remove unwanted criteria from an assignment rule
Siebel Assignment Manager Administration Guide |
