Siebel Assignment Manager Administration Guide > Running Assignment Manager > Process of Running Dynamic Assignment >
Generating Triggers for Dynamic Assignment Using the Command-Line Interface
You can run dynamic assignment using the Server Manager server component from the command-line interface using the Generate Triggers command and the parameters in Table 48. The command-line interface of the Server Manager is the srvrmgr program. For more information on using the command-line interface, see Siebel System Administration Guide.
Table 48. Generate Triggers Command-Line Interface Parameters
EXEC |
EXEC |
Install Triggers to DB directly |
FALSE |
Mode |
Mode |
Assignment Server and/or Workflow mode (ASGN, WORK, or ALL) |
ALL |
Remove |
Remove |
Remove All Triggers Mode |
FALSE |
TAMode |
TAMode |
All Territory or Contact Only mode |
ALL |
TrigFile |
Trigger File Name |
Output trigger script file name |
trigger.sql |
