Siebel Assignment Manager Administration Guide > Running Assignment Manager > Setting the Log Level of Assignment Manager EventsBefore running Assignment Manager, you can set event logs to view results. The Assignment Manager, Batch Assignment, and Workflow Monitor Agent server components are configured to use events. NOTE: The Trace Flags and Error Flags parameters are no longer used with Assignment Manager. In addition to the events used for other server components, the Assignment Manager, Batch Assignment, and Workflow Monitor Agent server components use specific events to log information related to assignments:
There are five levels in each of the events:
Assignment Manager uses two events for logging information when assigning object rows. For the evaluation phase, Assignment Manager uses the Rules Evaluation (Match) event. The following levels of information are logged for each level:
NOTE: As of version 7.7, level 5 is necessary for you to see detailed criteria value-level logging. For the assignment phase, Assignment Manager uses the Object Assignment (Assign) event. The following levels of information are logged for each level:
NOTE: You can set the log level of both event types to print a list with combined results. However, when assigning too many objects, these settings may create extremely large log files. To set the log level of Assignment Manager events
For more information on event logs, see System Monitoring and Diagnostics Guide for Siebel Business Applications. |
Siebel Assignment Manager Administration Guide |
