Siebel Assignment Manager Administration Guide > Running Assignment Manager >
About Server Administration Requirements After Configuration
After configuring Assignment Manager objects and attributes or altering assignment policies, it is often necessary to stop and restart various server tasks and components. Table 46 summarizes the required server tasks and components that must be restarted based on the type of configuration process. Detailed information on how and when to run these server tasks and components is provided in the remainder of this chapter.
Table 46. Summary of Server Administration After Configuration
Restart Assignment Manager |
Restart Workflow Monitor Agent |
Adding or configuring an assignment object, assignment attribute, or assignment criteria |
Yes |
Yes |
Yes |
Changing assignment policies |
Not applicable |
Yes |
Yes |
Activating or deactivating assignment policies |
Not applicable |
Yes |
Yes |
NOTE: If you want to automatically refresh skills without restarting the Assignment Manager component, set the value of the Refresh people skills interval (MaxSkillsAge) server component parameter to the desired update interval (the value must be greater than zero seconds). Then, when rules are released, Assignment Manager refreshes skills and recreates the rulecache.dat file at the periodic interval set.
