Configuring Siebel eBusiness Applications > Editing Applet Layout >
Checking Mappings
Sometimes mappings between Controls or List Columns and placehoders in Web templates can become invalid. This may occur when a Control or List Column object is inactivated or is deleted from the repository, but still appears on the Web template. It may also occur when a new Web template is associated with an applet, and the existing placeholder IDs for Controls or List Columns do not exist in the new template.
To check mappings
  1. In the Applet Layout Editor, click the Layout Canvas to select it.
  2. Right-click, and then choose Check Mappings.
    If mappings between controls or list columns and placeholders are invalid, you are prompted to delete it from the Web template.
