Configuring Siebel eBusiness Applications > Configuring Applets > About Run-Time Pop-Up ControlsFor controls or list columns of type Text or Field, Siebel applications enable specialized controls, such as a calendar or a calculator, to pop up at run time, depending on the field data type. Table 40 summarizes the data types and associated pop-up controls.
To cause a run time pop-up control to appear, the Runtime property of the list column or control must be set to TRUE. If there is a picklist defined for a field that has one of the types in Table 40, then a picklist pops up at run time, instead of a calculator or calendar. NOTE: The Read Only property of the list column or control must be set to FALSE to use the Runtime property to access run-time pop-up controls. |
Configuring Siebel eBusiness Applications |
