Configuring Siebel eBusiness Applications > Specialized Behavior Supported by Web Templates > About Search and Find in SWE Templates > Search Result Tag: <swe:this>Purpose: Depending on the property= setting, retrieves either the text alignment setting or the value for the current result field. Attributes: behavior varies depending on the enclosing context. |
Configuring Siebel eBusiness Applications |
