Configuring Siebel eBusiness Applications > Configuring the Customer Dashboard >
Configuring Communication Events to Populate the Customer Dashboard
You can use communication events to populate the Customer Dashboard. Examples of communication events are inbound email message, voice call, or Web collaboration work item. The Multichannel Def A communication event has been preconfigured to populate the Customer Dashboard with contact information for certain communication events. However, you can configure any communication event to populate the Customer Dashboard for any business component, based on information passed to the event.
The API for the communication between communication events and the Customer Dashboard is a member function UpdatefromCTI of the Customer Dashboard business service. The CTI administration views are preconfigured to call InvokeMethod_ (with UpdateDashboard as a parameter) when a significant event occurs and passes variables, such as Phone number and Number of calls in queue, as arguments.
To populate the Customer Dashboard during a communications command or event, you need to call the method to update the Customer Dashboard and pass three parameters, including the business component, the field for that business component, and the value that you are getting from this communication.
For example, the parameters listed in Table 74 instruct the Customer Dashboard to populate with contact information for the contact whose Work Phone # matches the ANI of the inbound call.
Table 74.  Customer Dashboard Parameters for Communications Events
Parameter
Example Value
ServiceMethod
Persistent Customer Dashboard.Update Dashboard from CTI
ServiceParam.Field
Work Phone #
ServiceParam.Value
{ANI}
ServiceParam.BusCompName
Contact
You can also call the Customer Dashboard business service from the communications event log. See the steps below for an example.
  1. Locate the Event Handler InboundCallReceived.
  2. Click on the Associated Event Logs tab.
  3. Drill down on the log LogIncomingCallContactFound.
  4. In the log parameters, you define the following parameters:
    Parameter
    Example Value
    ServiceMethod
    ServiceParam.Field
    Id
    ServiceParam.Value
    {Contact.Id}
    WorkTrackingObj.ContactId
    {Contact.Id}
