Configuring Siebel eBusiness Applications > Configuring the Customer Dashboard > Adding Business Component Lists User Properties to the Dashboard Business ServiceUser properties of the Persistent Customer Dashboard business service specify the business components and the list of fields available to display in the Customer Dashboard. These user properties are also known as Business Component Lists. Each user property name begins with List and is appended to make the name unique, for example List1, List2, and so on. The user property value identifies the name of a business component and the list of available fields. For example, Table 69 shows the preconfigured user properties that identify the Contact and Opportunity business components and their corresponding fields. This task is a step in the Process for Configuring the Customer Dashboard. To add Business Component Lists user properties to the Dashboard business service
Configuring Siebel eBusiness Applications |
