Configuring Siebel eBusiness Applications > Configuring the Customer Dashboard > Formatting Customer Dashboard Phone Number FieldsYou can configure the Customer Dashboard to recognize different telephone extensions. You use a business service user property to define the parameters that associate your company's telephone switch extensions to their full-length phone numbers. The user property name is Phone Number Prefix. Three values, separated by semicolons, define the parameters. The values are as follows:
Consider the example shown in Table 72: The example shown in Table 72 would allow a user to dial the extension 24565. The extension has 5 digits. The first digit, 2, is removed. The prefix, 650555, is added. The resulting phone number is 650-555-4565. |
Configuring Siebel eBusiness Applications |
