Configuring Siebel eBusiness Applications > Configuring EIM Interfaces > About EIM Object Types > EIM Interface Table Column Object TypeThe EIM Interface Table Column object type is an alternative representation of the Column object type, for columns that are child object definitions of interface tables. For a given interface table, the same list of columns appears as column children of the table object definition and as EIM interface table column children of the corresponding EIM interface table object definition. This is shown in Figure 20. The EIM Interface Table Column object type contains all the properties of the Column object type, in addition to some that are specific to EIM. NOTE: The Price List interface table EIM_PRI_LST is used in this and subsequent examples in the section. |
Configuring Siebel eBusiness Applications |
