Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer >
Resizing Shapes
You can resize shapes by dragging them in the ERD canvas or using the Resize options from the Layout right-click menu. To resize shapes
- Navigate to an entity relationship diagram.
For instructions, see Navigating to Entity Relationship Diagrams.
- In the ERD canvas, select the shape you want to resize and then do one of the following:
- Click an entity's connection point and then drag it to a new position.
- Right-click and then choose Layout > Resize and choose one of the following options:
Height by 1 |
Resizes the selected dimension by 1 pixel. |
Height by -1 |
Width by 1 |
Width by -1 |
Height by X |
Resizes the dimension selected by the number of pixels contained in one cell on the ERD canvas. The number of pixels can vary depending on the resolution setting of your monitor. |
Height by -X |
Width by X |
Width by -X |
NOTE: You can also use the shortcut keys displayed in the Layout > Expand menu.
